Question about DeLonghi Coffee Makers & Espresso Machines
I have a DeLonghi AC925EFY easitronic. The easitronic Knob no longer works,18months old
The circular easitronic control Knob does not wprk,only micrawave works on one setting using start button nothing else can be used,
MicrowaveSvc
  • 9086 Answers
SOURCE: My panasonic nn-t795sf has a
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, you may have a failed keypad. If that's the case see the rest of this solution.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
Posted on Sep 01, 2008
  • 10 Answers
SOURCE: Top knob no longer turns
The valve behind knob has probably gone bad and needs replaced(bad bushing from factory maybe). Check to see if your still under manufacturers 1 year warranty. Or order a new one off manf. website or ebay with model #. Good Luck, hope this helps.
Posted on Apr 11, 2009
localwonder
  • 6784 Answers
SOURCE: dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 25, 2009
  • 112 Answers
SOURCE: 2009 Cobalt factory remote start issue. I've been
sounds like a switch on the hood is bad are the brake switch
Posted on Feb 10, 2011
Testimonial: "Great Advice! Ended up being the hood switch, but unfortunately you have to buy the whole latch assembly with the switch installed. $90"
  • 2508 Answers
SOURCE: my 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Posted on Nov 20, 2011
Where can I find a replacement TIME Control KNOB for my Farberware Toaster Oven #103738, no longer available, under a two-year warranty. Is there a universal or generic knob that would work?
I found this knob on e-bay, don't know if it would work. Also you can search through google images and see if you can find one that matches yours. I looked for your parts number and could not find it.
http://www.ebay.com/itm/Delonghi-AS670-Turbo-Convection-Toaster-Oven-Replacement-Part-On-Off-Toast-Knob-/131982520058?hash=item1ebac56efa:g:b9kAAOSwXeJYD644
Nov 16, 2016 | Farberware Toaster Ovens
Wheres the bulb in a delonghi AC925EFY microwave
You must remove the outer cabinet from the Microwave to access the bulb. Remove every screw top, sides and bottom and slide the cabinet off.
Sep 06, 2016 | DeLonghi Microwave Ovens
My dem10 dehumidifier will not switch off. Micro switch foe the water tank is OK.
DeLonghi dehumidifier DEM10 repair - YouTube
? 0:52
https://www.youtube.com/watch?v=OudOYDwc-Ik
Jan 18, 2013 - Uploaded by jgphone
Here's what I found when my 5 year old DEM10 stopped extracting water ... How Does a Dehumidifier Work ...
how to mend it .com - Delonghi dem 10?
www.howtomendit.com > Cooling, Dehumidifiers
Hi I have a dem 10 my problem is when it is switched on the fan runs for a few minutes then it turns off if I turn the knob down until I hear it click off and turn the knob ... The room temperature has not altered so it cannot have stopped due to low temperature. .... If you exchange the capacitor the dehumidifier will probably work.
Broken dehumidifier - DeLonghi DEM 10? - How To Mend It
Jan 14, 2016 | Coffee Makers & Espresso Machines
Delonghi ac925efy working but making noise all the time
This indicates a triac switching semiconductor problem, the triac is a switching device that allows the microwave oven to run on different power settings, if the defrost cycle is running on a higher power level it is most likely the semiconductor, but the possibility remains that the keypad control board may be the issue.
Apr 14, 2012 | DeLonghi Microwave Ovens
How to replace Delonghi magnifica esam 3300 hot water/steam Adjustment knob ? Try around but can not take it out ...
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
Apr 17, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
What is part # for broken steam control dial eam3200
DeLonghi 5532125700 On/Off Knob
I think that's the one.
Jun 01, 2010 | DeLonghi EAM3200 Espresso & Coffee Maker
Heater stopped working suddenly
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 05, 2008 | DeLonghi Heating & Cooling
DeLonghi DFS 090 SO DUAL FUEL ELECTRIC COOKER NO LONGER HEATS UP. The grill and fan works but the electric oven no longer works.
I had the same problem,it was something to do with the oven knob switch ,i got an engineer out to fix mine or else just buy a new knob hope this helps
Jul 12, 2008 | DeLonghi Kitchen Ranges
DeLonghi 5108 Oil Filled Radiator no longer works?
The DeLonghi 5108 has no thermal fuse. There was a problem with the control panels and DeLonghi was to offer free repair. Details on http://www.cpsc.gov/cpscpub/prerel/prhtml91/91108.html
which includes a toll free number.
Dec 31, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
