Question about LG Dishwashers
Lg vario motor - LG Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
LG model LDS4821ST.... Top and Upper spray arms arn't rotating.
I have an LG LDF8922ST model with the same exact problem (16 months old as well). I think you are right about the vario spray system. Seems like the repair guys that come out are clueless and get very little assistance from LG customer assistance. I will never buy another LG product again.
May 28, 2010 | LG 24" XL Tall Tub Built-In Dishwasher -...
I have an lg ldf7811st and the bottom arm will not turn. I purchased the part 1267558 (motor assembly, vario spray valve) to repair it and I need instructions on how to install this part. Please advise.
you need to uninstall dishwasher and tip it backwards on the bottom of the dishwasher you will see a square panle remove the 2 screwsand replace the part then proceed in revers to put together
Mar 26, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LDF 7811 bottom sprayer not working - suspect diverter valve
The vario motor that attaches to the check valve can be accessed by pulling the unit and turning the entire DW over on its top.
This thing is not light and please be careful.
Remove the entire (black) base support assembly so you can see all the motors, etc.
Here is an example source for the vario motor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LG+LDF-%3d%3da9i1267558&PartID=1267558
Please report back what you end up doing, OK?
Sep 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher problem
The LG dishwasher family has a cool feature that alternates the full wash/spray power between the upper spray arms and the lower arm.
It is called Vario - with a motor that drives a check valve to route the water.
So, If you just open the dishwasher while it is running and look to see if all the spay arms are spinning, you will be disappointed.
Now, if you are having problems with dishes not getting cleaned, we need to take the next step. Post back what you find.
Good Luck!
Apr 09, 2009 | LG LDF9810ST Built-in Dishwasher
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
I have a LG dishwasher model # LDS5811WW is there a filter of some sort at the water intake? My water has be known to have sand in it . The dishes are not all washing some are some aren't.
No filter in these units. It is possible that sand has gotten into the sump assembly and is not allowing the vario motor to properly switch between the upper and lower spray nozzles.
Dec 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG dishwasher does not seem to clean items on lower rack
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Sep 29, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
67 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
