Question about Black & Decker CC1000 Shredder
Shredder will not turn on
I have plugged and unplugged my shredder, try to turn it on, the blue light doesn't come on. I tried a different outlet still the same problem. HELP!
    New Friend:
How can i fix my black and decker shreder cc1000? It wont power on and it is in good condition.
Posted on May 21, 2013
Black n& DEcker paper shredder CC600 will not turn on
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Apr 18, 2015 | Black & Decker CC600 Shredders
Won't turn on. Unplugged it to empty, when plugged back in, won't work. No light in either forward nor reverse. Have tried different outlets - still nothing! Please help.
Try putting the top back on it the opposite directions. There is a safety switch that only engages in one direction. It's a common problem easily rectified.
Mar 11, 2015 | Tech Solution TS-8000 Cross-Cut Shredder
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
My shredder won't power on. It is not overheated.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
Apr 11, 2012 | Office Equipment & Supplies
My paper shredder wont turn off
Shredders have sensors that tell it to turn on. Usually the there is a spring loaded button/sensor in the middle of the slot that you feed the paper in. Once the sensor button is pushed down, it thinks a piece of paper is being fed in and begins to turn the blades.
If your shredder won't stop running, I think the sensor button is stuck in the down position.
1) try pushing the reverse button for a while to see if it clears the problem.
2) if not, then unplug the shredder. Find the button/sensor near the middle of the shredder slot and with a tweezer, try removing any clogged scraps of paper near the sensor button to get it to pop up fully.
3) I've never seen a shredder with more than one sensor in the middle but if yours has more, make sure they are all in the popped up position when there is no paper in the shredder.
4) Plug the shredder back into the AC outlet and try it again. Good luck
Aug 08, 2010 | Office Equipment & Supplies
When i plug thr machine in the power light does not light up. Is their a reset button.
Hi your shredder may have a power problem or the power cord may be bad and you can also try plug the shredder into another wall outlet.
Aug 03, 2010 | Office Depot Ativa CX10W Shredder
I have an achiever heavy-duty crosscut shredder that I purchased in 2002. Since that time I have actually used the shredder around 5 times. The shredder turns on, shred for about 2-3 mins., then it stops....
does it finish the sheet of paper then shut off , or does it stop halfway thru the paper?
unplug the unit , open it up and see if theres staples or junk jammed in the cutting wheels/gears
there supose to turn off once its finished with the paper and turn back on when the next paper is inserted , theres a lil sensor that turns it on and a limit switch that turns it off
Jul 11, 2009 | Achiever CCS5000 Shredder
Paper got stuck. machine will not turn on.
First, check that the machine is properly seated on the waste container. There is a switch that prevents the shredder's operating if it isn't properly seated. Will your "ready" indicator light up? If the machine will not turn on at all, try something else in the outlet the shredder is plugged into. If there is no power to the outlet, you probably tripped the breaker. Reset it and proceed as follows. Turn your switch to "off". Unplug the shredder and flip the shredding head upside-down on a stable surface. Remove anything that was previously hanging down. Gently remove stuck stuff, keeping your hands in a safe position. Place the shredder head back on the waste container and plug it in. Most all shredders have a reverse on them for just this occasion. Work the machine reverse and forward, until it releases. When in reverse, remove whatever the shredder gives up, with the switch set to off, of course. This should get you back in the shredding business. Next time you're at one of the office supply stores, get some shredder lubricator sheets. Using these from time-to-time lessen the incidence of jams.
Enjoy! --W/D
Jul 11, 2009 | OfficeMax 0M96431 Shredder
Black & Decker CC1000 Shredder Logo
525 people viewed this question
Top Black & Decker Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Black & Decker Office Equipment and Supply Expert? Answer questions, earn points and help others
