The first time a bulb blew on the cooker hood the other light stayed permanently lit and would not switch off with the switch (the extractor fans continued to work ok with their switches.) The hood was still under warranty so the indesit engineer was called and he replaced the control board. A bulb has blown again and we seem to have the same problem but the warranty has run out. Surely this cannot happen each time a bulb goes - do you know if this is an inherent problem with this type of cooker hood
Comments:
Jan 23, 2009
- The control board and new bulb were replaced in July last year and the bulb blew last night. I have not tried replacing the control board myself - still trying to decide what to do . Seems a bit much if the control board needs to be repalced each time a bulb goes.
-   First one light went out; and soon, they all went out. But my problem was not the switch; instead, there was a problem with the socket that holds the bulb. Bottom line, I had to replace all four light assem. :(-   Guest
Jan 29, 2009
-   I have the same issue in that one of the bulbs have blown meaning the other one is constantly lit. How do i replace the circuit board and were can i get one as there is no model number shown anywere?-   Guest
Jan 22, 2009
-   Hi--I have the same problem with a zephyr palermo, although this is our first bulb blowout. I am contemplating replacing the control board (my warranty has also expired). How long did the light function before blowing out again, and have you tried replacing the control board yourself?
Thanks
Michele-   belly_btton
require english installation manual for euro grand rangehood WX0601- translated from chinese into...
(More)
require english installation manual for euro grand rangehood WX0601- translated from chinese into very bad english instruction
how do you change bulb on hotpoint chimney hood model htc9t I can get the unit out but how do you...
(More)
how do you change bulb on hotpoint chimney hood model htc9t I can get the unit out but how do you get the bulb out to replace
