Question about Sport & Outdoor - Others
Carl lewis mot 25 treadmill drive motor not getting power
Mouse ate all the wiring. I have rewired the treadmill computer shows all windows active. rear motor drives platform up and down. switch on computer console active tilts platform up and down. but treadmill doesn't run. Has anyone got any ideas what to do? or test next? Cheers Mike
    Genius:
  • Sport & Outd... Master
  • 1,669 Answers
Maybe the mouse is sleeping in the motor? First, try to release the treadmill belt pressure so that you can turn the rollers by hand. If all of the rollers turn except one, that is probably the drive roller. If you are careful you should be able to take the belt off and get to the drive roller and its motor. Check the motor is getting power. There is probably a reset switch on the motor, reset it. If it still doesn't turn..replace the motor.
Posted on Jan 12, 2013
  • Mike W Jan 13, 2013
    Thanks Leigh, I should have said I put an external 200 volts dc on the motor and the treadmill functions well. But I don't know if the microprocessor on the console runs the speed or the motor pcb (JD-230E/E) Thanks Mike
mastermaid
  • 502 Answers
SOURCE: carl lewis instruction manual for
ask here:
manualfox.com/link/carllewisfitness.htm
Posted on Nov 13, 2010
ginko
  • 19396 Answers
SOURCE: Hi, I have a commercial
Hi.
If there is incline fault, then the sensor must be calibrated. The error may happen even if you do not do anything. sensor goes out of calibration and you get e5.
The only reset you can do is by disconnecting power and removing console batteries if installed (that depends on the treadmill model).
I suggest contacting Techogim and following the procedure to calibrate the sensor. Contacts are listed at the right hand side of this page, click: Contact Us.
Posted on Sep 13, 2010
SOURCE: reebok s9.80 rbtl69608 treadmill - console only
So I had the same problem it was just stuck on the main screen. It just went beep beep beep. After much tampering. I Opened the console and unplugged the cable that runs from the I fit to the computer board and now everything else works great.
Posted on Feb 23, 2011
  • 456 Answers
SOURCE: I have an 8100 ES
hi.
the bearings in these machines should be lubricated and sealed for life. they are not designed to be touched.
it sounds like you have done the important bits. belt lubrication and blowing out any debris that may be there.
squeaks like this can be incredibly difficult to find, but can also be incredibly annoying.
the main things that you can do is keep watching to try and find exactly where the squeak is coming from and check for anything wrapped around the edge of the roller.
keep using the belt spray, and the compessed air.
a good grade silicone lubricating spray used at the edges of the rollers, by the bearings and around the motor and gearbox unit may also help but do not get this spray on the belt as it can be very slippery.
squeaks like this can start and stop on their own or develop slowly and go just as slowly.
keep doing the maintenance you are doing, and use the silicone spray as described above.
it may take a little while for the spray to work its way into the bearings as they are fairly well sealed but you should notice an improvement after a few days.
please feel free to ask for further advice if you need
Posted on Apr 02, 2011
SOURCE: Error E07 on Carl Lewis
does any1 know how to fix the e07 error on the carl lewis tredmill or why is has appeared?
Posted on Dec 15, 2011
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
I have lost my carl lewis treamill mot 566 instructions
please go to next web page:
1) www.fitnessrepairparts.com you must pay.
2) http://fitnessmanulsonline.com this is free download
3)http://pdfservicemanual.com you must pay.
4)http://manualsfactory.com
sincerely.
Nov 06, 2011 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
I need to print out a instuction manual for a carl lewis motc99 treadmill
http://cgi.ebay.com/Carl-Lewis-Treadmill-MOT566-and-MOTC99-Instructions_W0QQitemZ130354874033QQcmdZViewItemQQptZUK_SportsLeisure_ExerciseFitness_Treadmills_JN?hash=item1e59c186b1
Jan 17, 2010 | Exercise & Fitness
I need an instuctions on how to start a carl lewis treadmill
or maybe one of the newer manuals at carl lewis might be similar.
http://www.carllewisfitness.co.uk/html/English/IB_UK.htm
Instruction manual for the carl lewis mot566 treadmill
Find it at manualfox.com/link/carllewisfitness.htm
Nov 13, 2009 | Exercise & Fitness
Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
I need a manual for a carl lewis treadmill
You can download the Carl Lewis Treadmill manual here
Apr 20, 2009 | Landice L7 LTD Executive Trainer Treadmill
Sport & Outdoor - Others Logo
476 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
