Question about Samsung PN51D450A2D Plasma TV
Calibration needs to be set - Samsung PN51D450A2D Plasma TV
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
Need to know how to calibrate
What is it exactly you're trying to calibrate? typically in any form of calibration, you need a unit and method of measure, initial specifications so you know where you're calibration needs to be set before, during, and after your work. and a method of adjusting the item to be calibrated. usually a haynes manual, or other form of service manual will provide you with more detailed instructions on the specific type of car/truck/ etc you're working on. Hope this helps
May 09, 2016 | Cars & Trucks
I need to Collaborate my SAMSUNG GT-S3370?
To Calibrate the touch screen:
1 - In Menu mode, select Settings ? Phone settings ?Calibration.
2 - Tap the target on the screen until the calibration is finished.
3 - Select Yes.
May 25, 2011 | Samsung Lands Phones
My touch screen needs calibration
Hey
its simple just go to Menu > Settings > Phone Settings > Calibration
you'l be asked to tap on screen until the calibration settings are done.
Thanks.
May 03, 2011 | Samsung Star GT-S5233 Cell Phone
When calibrating, it onlt feeds a couple labels
Use the Menu system to calibrate, follow the instructions and it should calibrate with New settings. Calibration by setting it to calibrate on head close or bootup only loads factory settings.
May 03, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Reseting KA08 due to bad calibration
my KA08 mini does not respond when i press the menu button. therefore i cannot access the menu....what do u suggest
Jul 06, 2009 | Cell Phones
Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Mar 18, 2009 | Zebra 105SL Thermal Label Printer
Plotter needs recalibration
You need to enter the service calibrations menu, to do this select the set up menu, once inside the set up menu press the up arrow & enter keys together. This will take you to the service tools menu, from here select service calibrations (printhead alignment and colour calibration are both in this menu). If you still here problems after you have calibrated your machine or the calibration fail replace the printheads.
Oct 16, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Calibration
If the media sensor is positioned correctly and the printer is set for an autocalibration on power up and printhead close a manual calibration is not really needed. However, here is the information that is the easiest way to run a manual calibration.
Manual Calibration
With the printer at a ready state, press the MODE button two times or until the CALIBRATE light comes on.
Press the FEED button.
Once this is complete press the MODE button four (4) times to save these settings.
Mar 07, 2008 | Zebra Stripe S600 Thermal Label Printer
Samsung PN51D450A2D Plasma TV Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
