Question about Car Audio & Video
Boss R3400 amp sub make heartbeat while protect light on
The amp protect like stays light the speakers make heartbeat sound when hooked up even with the protect light on
Electro
  • 38 Answers
SOURCE: My amp wont put out sound
If your amp powers on with protection light, try the following: Unhook all input RCA cables on the amp. See if that helps with protection light. With a DMM, measure the voltage going into the amp's power connectors. If it's less than the minimum required by the amp, protection will kick in. Also, check for over voltage, too much volts can also trigger protection. Check your speaker wires for short. If some of the wire strands are loose and touching each other or the chassis, it can cause protection. Basically try the amp with no RCA inputs, no speakers attached. If the protection doesn't go out, then you have an amp problem.
Posted on Mar 03, 2006
ampman
  • 98 Answers
SOURCE: Protect light flashing/ticking
Yes make sure your powers and grounds are all ok. If you have round glass fuse in the power wire replace it even it it looks good. Ive seen those fuses melt the solder internally so they will be "blown" but look as if they ar eperfect.... if that does not help your amp needs repaired. go to my website at http://home.comcast.net/bigmikeselectronic/repair for more info. I may be able to repair it fo ryou or buy it form you as-is...
Posted on Nov 27, 2006
  • 631 Answers
SOURCE: car amp
The most common reason for this is shorted output transistors. To confirm that the problem is in the amplifier, disconnect all speaker wires and the RCA cables. If the amp still goes into protection, check the DC voltage across the B+ and ground terminals. It should not drop below 11 volts. Also check the remote voltage.
If the amp continues to go into protect with no external connections (other than B+, remote and ground) and the voltage remaiins above 11v, the amp is defective.
Posted on Nov 06, 2007
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
  • 21 Answers
SOURCE: rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Posted on Mar 21, 2009
I had my boss 2400 watt 2 channel amp hooked up in my car. I had one sub on each channel and one of my subs blew. I unhooked the positive speaker wire on the blown sub, everything was fine. Driving down...
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
Sep 06, 2011 | Boss Car Audio & Video
Why is my sub heartbeating and my amp in protection mode
Sounds like a shorted speaker wire. Try disconnecting speaker from amp and see if protection light goes out- if so replace bad speaker wire. Only other issue i can think of from your short description is that you might have a bad ground going to amp or the remote power wire is bad. try running a new ground wire to a clean metallic spot on you cars chassis close to where the amp is located. Good ground = good clean sound
Mar 04, 2011 | Car Audio & Video
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
ALL THE WIRES ARE RAN CORRECTLY,THE GROUND IS SECURE UNDER A BOLT UNDER THE SEAT,THE SUBS ARE HOOKED UP RIGHT,BUT THE PROTECTION LIGHT IS STILL ON
the protection is on because if any speaker has internal electric problems as open circuit or short circuit, need to be checked
Jan 03, 2010 | Boss C650 Car Audio Amplifier
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Low amp output
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode).
Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too.
The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
Feb 15, 2008 | Jl Audio E2150 Car Audio Amplifier
Not producing sound
It sounds like the power supply may have failed. I'm not familiar with that particular Boss amp but many amplifiers will light the power indicator even though the amp isn't operating.
Have you checked your speakers to see if they're blown?
Have you checked the wiring to make sure the speakers are still connected to the amp?
Dec 19, 2007 | Car Audio & Video
Car Audio & Video Logo
257 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
