Question about Kenmore Washing Machines
Tub wobble while spinning
Model#23932200 tub wobble out of control while spinning cloths
    Sergeant:
  • 291 Answers
I don't have experience with Kenmore top loaders and the tub is set-up quite differently from the machines i do work on. However, there are a whole bunch of videos on YouTube on machines just like yours. Find them here:
http://www.youtube.com/results?search_query=Kenmore+Washer+tub+&oq=Kenmore+Washer+tub+&gs_l=youtube.12..0.41231.41231.0.43518.1.1.0.0.0.0.262.262.2-1.1.0...0.0...1ac.1.NSNP1Q5qPwQ
Also here is a cool site on whirlpool machines that should be quite similar if not identical to yours, with videos:
http://britishjames.com/whirlpool_washer_repair_videos.htm
Good luck.
Posted on Jan 12, 2013
MNTECH
  • 1543 Answers
SOURCE: Loose tub on GE WJSR2080V
Reach (or look) over the tub, just under the metal top, at the four corners of the machine to see if the rubber tab dampening straps are OK. (not broken) If broken, use putty knife to push in 2 spring clips at very top of front panel (a couple inches in from the L and R side) and pull to take front panel off. Remove two 1/4 hex head screws holding top to side panels. Remove top. (looks like your model has a lid switch which can be unplugged by the back splash.)
Also check that the inner tub does not rock independently of the outer tub. If it does, pull agitator and tighten large left hand threaded nut.
Posted on Sep 13, 2008
JR JR
  • 116 Answers
SOURCE: empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
SOURCE: Spin cycle shuts down when tub wobbles on GE washer
Bad lid switch
Posted on Feb 24, 2009
t1m130
  • 86 Answers
SOURCE: The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Posted on Mar 14, 2009
  • 84 Answers
SOURCE: washer tub wobbles, washer is level
Sounds like a drum bearing problem , unless you are an engineer , suggest call service agent for estimate.
Posted on Nov 08, 2009
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Whirlpool washer model wslp1100d after the rinse
Hi Derek.
There are several different problems that may result in basket wobbling and machine shaking heavily during the spin cycle. Sometimes the shaking can result in spin cycle not ending, like in your case.
To find out what the problem is the washer must be taken apart and the tub removed.
A common situation is given by a defective drive hub.
At the end of this comment there is a movie showing how to reach and replace the drive hub in whirlpool top load washers. In this washer you will find a more complicate device instead of the hub shown in the movie. There is a pulsator, the balancer and other parts that must be inspected. The two assemblies are indicated respectively as part 52 and 56 in diagram nr.1 below. Here the part list: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470626#d26470626
If you find a foreign object such as a cloth below the tub, then that can be cause for the shaking and wobbling.
If the parts below the tub are OK, then one of the suspensions may be broken. Suspension (damper) is indicated as part 36 in diagram 2. Here parts: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470625#d26470625
Here diagrams:
Diagram 1
Diagram 2
Here the video:
utube.png You-Tube video "aj-HSUOuBBA" placeholder (do not delete) utube.png
Regards.
Ginko
Nov 20, 2011 | Washing Machines
Whirlpool washer model wslp1100d wobbles at start of the final spin cycle then abruptly stops and returns to the start of the rinse cycle
Hi Derek.
A cause for the problem consists in a defective drive hub.
Here diagrams:
Diagram 1
Diagram 2
Here the video:
Regards
Ginko
Nov 19, 2011 | Washing Machines
Empty washer tub wobbles during spining, plus burning smell
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Off balance spin cylce
The base of the tub assembly rests on a white plastic ring called a 'snubber'. If any type of lubricant gets in this area, the tub will wobble excessively. The major cause for this issue is a failed transmission where oil has leaked out and into the snubber. The transmission may be warranted for 10 years. Check your owners manual. A good method to check for oil is to tilt the machine back and remove the plastic cover in the center of the pulley, if it contains oil, the transmission is leaking also look at the inside cabinet wall for signs of oil splatter.
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spin
Does this happen with every load? I've had this happen occasionally but it was caused by one or two heavier when wet pieces of clothing that caused the tub to get off center and it would wobble out of control. By just rearranging the wet clothes to balance the tub it stopped wobbling. But only after making sure that the heaviest objects were on opposite sides if the tub.
Nov 11, 2007 | Washing Machines
Washing Machines Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
