Question about Sony Ericsson P800 Cellular Phone
Internet through bluetooth
I am having sony ericsson P800 but am unable to connect it through bluetooth... i have installed bluesoleil on my laptop and am even able to transfer data between laptop and cell but when i click dial up connection it gets failed up... i have even tried it again by restarting the cell and the laptop and by choosing another port for bluetooth.. kindly help me..
Try using a microtune bluetooth device instead of a bluesoleil one. i've encountered the same problem before.
Posted on Jul 06, 2007
SOURCE:
Sony ericsson w8 e16i cannot installed the pc companian for the second time... can connect phone internet to laptop
I want to connect internet connection from my mobile sony ericsson w8 to laptop through anyone data cable or or Bluetooth but it will connect then give me any solution to connect the internet ......
Sep 07, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I have an sony ericsson w700i,i want to connent to internet in my laptop by use of my phone(by bluetooth) i have no cable,i want to use bluetooth,how can i do this?
Thanks for visiting FixYa!
You have a Sony Ericsson W700i which has a Java Operating System. Maybe - and I do mean maybe - you can tether your PC to the Internet with your phone IF your phone is supported by the Sony Ericsson PC Suite.
I say maybe, because I have never used a w700i with this PC Suite before.
You can download the PC Suite here and install it on your PC.:
http://www.softpedia.com/get/Mobile-Phone-Tools/Sony-Ericsson/Sony-Ericsson-PC-Suite.shtml
If your phone is supported by the PC Suite, you can look under the TOOLS section of the PC Suite and click on Internet Connection. (If it works, let me know.)
Also, if you can tether, and you use Bluetooth - your Internet connection will be slower than if you use a USB cable.
Mar 19, 2011 | Sony Ericsson W700i Cellular Phone
Can't pair my HBH-PV705 bluetooth headset with my laptop
You need to have a bluetooth stack installed, so that you have "bluetooth places" available, where you can link up the headset.
A good instruction (for XP) is shown here.
Bluesoleil is definitely a good option.
May 20, 2009 | Dell Inspiron 1525 Notebook
Bluetooth file sharing problem
You can transfer only media files (don't know why). To do it, go to media, prees "menu", select "recieve using bluetooth" and after that send from sony ericsson.
Mar 28, 2009 | Sony Ericsson K800i Cellular Phone
Vista cant install jabra bt8030
I just got the same headset and they don't ship with a driver CD.
Try using Bluesoleil for bluetooth connectivity on your laptop. You can get it from
http://www.bluesoleil.com/
Bluesoleil comes with its own drivers for a wide variety of bluetooth functions so you don't have to hunt for specific drivers.
Please note that your bluetooth hardware has to be compatible with bluesoleil. There is is utility on their website that lets you test the same.
Hope this helps.
If this helps, can you have a look into my problem and see if you can help?
http://www.fixya.com/ThreadView.aspx?prdid=919866&thid=2267585
Thanks!
Mar 11, 2009 | Jabra BT8030 Bluetooth Headset
No connection beetwen my Sony ercsson p900 and my computer by usb
hello there!!! thanks for using Fixya.com!
just a little information...
PDA USB Sync/Charger/Data Cable for Sony-Ericsson P800,Sony-Ericsson P900 Features:
  • USB Sync/Charge Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
  • Auto Sync with computer in USB port and charge Sony-Ericsson P800,Sony-Ericsson P900 PDA with same cable
  • Directly connects with USB port, need no extra power
  • Plug and play, need not software installation
  • Eliminates the need for cradle and AC/DC converter when traveling
  • Compact, lightweight and easy to use
  • One of the best USB hotsync data cable for Sony-Ericsson P800,Sony-Ericsson P900!
    If you experience problems when using the USB cable during synchronisation:
    1. Check that the USB cable is properly connected to the phone and the computer.
    2. Make sure the phone is turned on.
    3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
    4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.tang-shop_2031_105590869 Or you may go to this website for further information http://www.sonyericsson.com/cws/support/phones/detailed/usbcableissues/p900
  • Feb 09, 2009 | Sony Ericsson w580i Cellular Phone
    Transferring contacts via bluetooth from a sony ericsson
    you have to install PC suite first..and then start to sync files between pc and mobile...if you have already done that and doesnt work..try using the data cable...
    hope this helps
    Dec 16, 2008 | Sony Ericsson K750i Cellular Phone
    I cannot connect my P800 to a pc
    i used to have a similar problem, try a bluetooth dongle that supports the frequency, i had one which worked perfectly fine and then it got damaged and since then all other usb's i tried did not work, try dongles which are compatible with p800
    Dec 01, 2008 | Sony Ericsson P800
    Unable to transfer photos from phone to laptop using usb and bluetooth
    What is your phone model?
    do you have "pc suite" of your phone installed on your laptop?
    Oct 31, 2008 | Sony Ericsson V600i Cellular Phone
    P800 memory
    I am sorry but the 1 GB stick is not compatible. The P800 can only use regular DUO cards (the biggest size being 128 MB). The 1GB is a PRO DUO.
    Apr 12, 2008 | Sony Ericsson P800 Cellular Phone
    Sony Ericsson P800 Cellular Phone Logo
    54 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Damen Wong
    Damen Wong
    Ekse
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
