I need an instruction manual for the Capsela 680 Lift n' Load hydraulic kit. Where can I get that?
Capsela 680 Hydraulic vehicle kit
SOURCE: Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I had the same problem with a 3 ton sears jack and here is what I did. I pulled the jack all the way to the top, the piston should be fullley extended. Then I added oil to the jack. You will have to work the piston back and forth, (.5 in or so) and continune to add oil while doing this until no more air comes out. The method fix my 3 ton jack. Hope this helps
Posted on Jun 08, 2009
wilsodfarm
  • 986 Answers
SOURCE: hydraulic clutch 1995 chevy 1500 truck
I know you dont want to hear this but it sounds like the clutch plate is in backwards.
Posted on Oct 19, 2009
  • 8 Answers
SOURCE: need to know why hydraulic lift wont work
Are you using 90 weight mineral based oil?
Have you tried adjusting the controls? You'll need a manual for details on adjustment. You can get one at www.Ford8N.com
Posted on Dec 22, 2009
SOURCE: Wesco Hydraulic platform lift needs pump valve re-assembled.
Go to: www.wescomfg.com/instructions/pedalift_seal_kit_with_pricing.pdf
Posted on Feb 24, 2011
mastermaid
  • 502 Answers
SOURCE: Hydraulic system of Bobcat 642b
Ask here, they will find every Bobcat manual or schematics.
Posted on Mar 06, 2011
Where do I check the hydraulic fluid on a mahindra 3016 hst
I'm not terribly too sure about the Mahindra, but I have recently had to check my hydraulic fluid and I consulted with the manual. Do you have a manual for your vehicle? If you don't, then I would get a repair kit which should have some instructions that could help you out with your situation. https://www.hydrapakseals.com/storefrontCommerce/hydraulicRepair.do
Feb 24, 2015 | Mahindra Cars & Trucks
How do I remove starter from 1993 Chrysler town and country 3.3
First, go to Pepboys and buy a repair manual for this vehicle. You need a repair manual with full instructions and probably a hydraulic lift to get underneath~!
Feb 17, 2015 | 1993 Chrysler Town & Country
The hydraulic life quit working on the tail gate. are they replaceable or fixable?
Often they are... places like jcwhitney.com or such will let you match specific to your vehicle. I'm not a fanboy of jcwhitney, there are many sources so feel free to search, but here are some links to examples. Just enter your make, model, year and you'll find out if yours can be done. Good luck!
http://www.jcwhitney.com/lift-support-kits/p2020480.jcwx?filterid=j5
http://www.jcwhitney.com/strong-arm-replacement-lift-supports/p2002992.jcwx?filterid=j5
Aug 14, 2011 | Kia Sedona Cars & Trucks
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
My right side steering doesn't engage at all
first check to see that you have enough hydraulic fluid in the resevoir and that the right side hydraulic pump is not leaking....there is the possibility that the lever that controls the right side is slipping on the shaft where it connects to the pump causing this condition...if you have the manual the mower came with ..you need to go to the procedure for bleeding the air out of the pump....if it is not in the manual, you can call a dealer for the instructions or order a service manual....if all the above does not fix the problem... then you may need to get a rebuild kit for the hydraulic pump...these are not too expensive..but they beat buying a new pump as pumps are anywhere from 400-700 dollars
May 26, 2011 | Husqvarna Zero Turn Mower Z5426
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Villager GE 95 liquid escape in a brake system
It is a brake load sensoing valve that applies more pressure to the rear brakes as you load the vehicle. It is $375 from tascafordparts.com. Get one from the junk yard or just bypass it.
usually just the lines are leaking and can be replaced.
Valve, Brake Load Sensor Proportioning The Villager has a brake load sensor proportioning valve (2B547) that is mounted on the vehicle frame and connected to the rear axle housing (4010) . When the vehicle is unloaded, the brake load sensor proportioning valve closes and partially reduces hydraulic pressure to the rear wheel cylinders (2261) . As the vehicle is loaded, the weight presses down the back end of the vehicle on the rear springs (5560) . This activates the brake load sensor proportioning valve which opens and supplies more hydraulic pressure to the rear wheel cylinders . When the vehicle is fully loaded, the brake load sensor proportioning valve is fully open and provides full hydraulic pressure to the rear wheel cylinders .
Jun 26, 2010 | 1995 Mercury Villager
Need a lift
hi, i always recommend using a lift kit for safety but, you can use a hydraulic floor jack to lift as well. they are really strong and sturdy. i would recommend using one hydraulic floor jack on each axle.
Mar 04, 2009 | 1995 Dodge Dakota
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Go to Pinpoint Test D.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
Jan 04, 2009 | 1989 Ford Mustang
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
