Question about Maytag Neptune MDE7500AY Electric Dryer
Replace drum baffle on Maytag MDE7500AYW dryer
How do I remove the front of the dryer in order to gain access
    Novelist:
  • 101 Answers
When you open the door of the dryer you will find screws on each side. First remove the screws that hold the door on, then move to the next side. Once the screws are out you should be able to lift the front panel right off. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad that I could help.
Posted on Jan 22, 2009
Maytag elec dryer belt broke / how do you open and replace
Remove the 2 screws on the bottom of the front panel to remove the panel and gain access to the drum.
Nov 22, 2012 | Maytag Dryers
Replacement of a drum baffle, how to?
inside the door thier is 2 screws that hold the hinge to the front panel remove those and the 2 on the other side gently lift and pull the door off. pull the front panel off and look and find directly below the top a clip that holds down the top to the front panel remove those clips (one on each side) pivot up the top and rotate the drum by hand so that the baffle that needs to be replaced is on the top. replace baffle and reassamble in reverse order
Jul 19, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Can you remove the plastic ridges inside the drum of a Maytag dryer? There is something caught and makes a noise.
usually the screws for these are actually on the outside of the tub screwed into the baffle device... will require you to gain access to outer portion of tub.. good luck to you.
Jan 27, 2011 | Maytag Dryers
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Nov 21, 2008 | Maytag Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
the top cover is fastened by spring like tabs on the machine rear. the front edge of the top merely clips to the front panel. the top needs to be removed to gain access to the bolts that hold the front panel on. these are inside the top corners of the machine. once these are out, the front cover should just pull up to remove. there may be a light connection and the door switch wires here too. then you can get to the screws that hold the baffles in place.
Dec 27, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
393 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
