Question about Hoover Whole House Bagless Upright, UH71209
LOST SUCTION what now ?
Brand new, used 4 times, once in Garage....Maybe It's hurt now. Now turns off on Thermal protection, dust cloud forms at carpet. Hepa looks new, top filter clean, cleaned hose, without remedy. Disassembled ALL looking for a clog. Rodded the vertical chamber that goes up handle to canister top starting from the fan end. Reassembled all, SAME THING. Will get a new belt next. Any other tips ? Wife is hopping mad.
  • bruce_wyche
    bruce_wyche Jan 15, 2013
    Plug WAS in hose. Clamp hides the fact. Blew on tool hose and plug was proven. THANKS !
    Scholar:
  • 108 Answers
If it has suction at the tools and lots of it, you're not plugged. If there's low suction on the tools you're on the right track. Follow the airways back and you'll find the plug. Also check the base where the dirt goes 90 degrees that's almost always where a plug is going to start. A new belt might do it if the cloud you're talking about is rubber dust and rubber smell. Take the bottom plate off and look for plugs/a stretched belt there. It's really tough without seeing it to help. They can have bad motors from the factory as well which can make for smoke and burnt electrical smell.
The vac Dr
Posted on Jan 14, 2013
3 Suggested Answers
  • 294 Answers
SOURCE: Hello,We have an Hoover Mach 5 Cyclonic vacuum
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Posted on Apr 21, 2010
SOURCE: no suction power ,brush wont spin on carpet power nozzle. When it
You need to replace the belt that turns the brush.
Posted on Jul 03, 2010
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Miele s7000
My question is what kind of dirt are you trying to pick up. Regular dirt does not plug up in twenty minutes. If you see dirt flying around that tells me your vac hose or parts that have a suction is plugged up. Take the hose and hose attachments off and make sure there is no dirt inside.If they are clear check the inside of the vac for dirt as well. Check your filter which is back of the vac bag as it may be plugged as well. The filter should come out to be cleaned.
Dec 21, 2017 | Vacuums
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Samsung sc8442 vacuum - has lost its suction and makes a meduim to high pitched humming noise if turn up above halfway on the suction. this also makes the red light come on. I've cleaned the filter and...
there are several filters. when you take the dust box out, you need to clean this filter as well
http://www.4ourhouse.co.uk/cgi-bin/finder.pl?ftype=443401&brand_change=&section=0&path=&hb=0&brandset=9925&model=1068934
Feb 01, 2010 | Samsung Vacuums
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Dust....dust....dust
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=662824
Posted by Kitkatman on Jun 11, 2008
I recently bought a house with an older Electrolux Central Vac system. I'm unfamiliar with them, so I'm not sure how to deal with this: I cleaned up some mortar dust with it, and noticed not too long after that when I went into the garage, there was a fog of dust. The hose from the unit is venting into the garage. Is this normal? I have since used it for everyday household cleaning and each time I go back to the garage to a cloud of dust. Is there anything I can do? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that the unit you have may have to be vented outside as I am not familiar with this particular unit, or it could very well be that it is missing a filter or the filter you have inside already is shot and is in need of replacement or on some central vacs there are paper filter that go over the cloth type filter. Again, I am not familiar with this older unit but feel free to contact the Electrolux Factory or Manufacturer and give them the model # and the serial # for the unit and they will have a breakdown of if it should be vented and what type of filtration it should be using. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 11, 2008 | Electrolux Central Vacuum
Hoover Whole House Bagless Upright, UH71209 Logo
148 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
