Question about IdentityGuard Cross-Cut Shredder
Overheating Runs for five seconds and stops. Makes grinding noise. I see sparks when I look up through air intake on the bottom.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Have you ever oiled it?
Posted on Jan 16, 2013
2003 Mazda Mazda6 V6 Overheating + Grinding Noises
Is the serpentine belt still intact? The grinding noise maybe the water pump which would account for the overheating.
Feb 17, 2014 | Cars & Trucks
1990 toyota 4runner knocking noise from air intake will turnover but wont start
Knocking noise in the air intake or do you mean a lifter noise,because you let it sit the lifter are not charged up or solidified,so you dont get adequate compression when you turn it over.if you have fuel and spark thats fine what about compression,noise from the air intake make me wonder if the timing belt is intacted.
Feb 04, 2013 | 1990 Toyota 4Runner
Fan noise
Is it free of dust , vents? The fan always comes on at boot. The RPM's will change when the sensors detect a certain temp to prevent overheating and damage to your machine. Is it getting sufficent air flow from the fan intake on the bottom through the machine to the exit vents?
Dec 22, 2012 | Toshiba Satellite L455D-S5976 Notebook
Overheat radiator fan runs for a few seconds makes a grinding sound
Is the fan a viscus coupling or electric elec is mounted on back or rad viscus coupling is connected 2 engine.
If connected to engine u will need 2 replace this unit un bolts from water pump need special spanner.
Tthe other the other one is electric fan there is a control some times in hose frome engine the other type screwws in to the side of radiator this unit controls the temp that switches on fan worn out get replacement un screw and replace it hope this helps u
Sep 02, 2012 | Gentex 2004 Mercury Grand Marquis - All...
Rear-end grinding noise in 1993 GMC Sierra 1500
your description sounds like the gears inside the the same differential you just replaced.
Oct 13, 2009 | 1993 GMC Sierra K1500
Gas dryer runs sometimes, not others.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dhjhdf
Feb 15, 2009 | Magic Chef CYG4000AWW Gas Dryer
Coffee machine will not grind the coffee beans?
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
Dec 13, 2008 | Saeco Vienna SuperAutomatica Coffee...
Five second delay with pump
check the intake of the pump. It may be clogged with sludge or debris.
Oct 02, 2008 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Honda civic hybrid 2003 - engine or transmission noise?
hi it is quite possible it is coming from the air box /filter and is just air intake noise chris (merlinv12)
Jun 22, 2008 | 2003 Honda Civic
IdentityGuard Cross-Cut Shredder Logo
64 people viewed this question
Top Identity Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
