Whirlpool washer model wfw9150ww01 won't dispense bleach
This washer will dispense detergent and softner properly but will leave bleach in the dispenser. Can't see a reason why. Help?
  • rickdoan71
    rickdoan71 Jan 16, 2013
    B.H. Thank you for your response. I pulled the top off and located the three valves. I could not see any reason i.e. loose wiring etc as to why they aren't working. From the configuration, I thought if I tried just cold water on the white cycle that might work, just to try a different valve, but to no avail. So, is there a way to test these valves? Continuity? I'm a licensed electrician so I'm comfortable troubleshooting, just want to know what I'm looking for. Thanks! Rick
    Sergeant:
  • 291 Answers
My guess is that the valve that pushes water into the bleach compartment has stopped working. It should be accessable from the top. I have some maytags similar to your machine that i have to remove the front panel to remove a couple screws to lift the top like a car hood. Not sure about your machine though.
Posted on Jan 12, 2013
eagle338
  • 4889 Answers
SOURCE: Bleach and Fabric Softner Dispenser
This is absolutely normal and you dont have to worry about it..
The reason for this:
The fabric softener compartment uses an over flow method to get the fabric softener out of its compartment and into the wash load. Water comes up underneath through a syphon tube and gently fills the fabric softener dispenser and causes it to over flow in its diluted state. The reason for this is that it is the most effective way for fabric softener to be diluted prior to hitting the clothes in the drum. Fabric softener has to be diluted before coming into contact with fabrics.
This is in contrast to how detergents dispensers work which simply flush the soap powder in to the drum by water being squirted on to it from above.
It is perfectly normal to have a fabric softener dispenser full of clean water after the wash cycle. Just lift and empty it out when you need to fill it with fabric softner for your next wash
Posted on Dec 10, 2007
SOURCE: NEPTUNE WASHER
My washer had the same problem, first not dispensing bleach or softner and then it began stopping altogether several times during the wash cycle. One we removed the water hoses and thoroughly cleaned them out, the problem was solved-apparently not enough water was flowing and the washer couldn't cycle properly. Good luck.
Posted on Feb 18, 2008
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
  • 99 Answers
SOURCE: Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Posted on Feb 07, 2009
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
Cabrio wtw7600xw2 when water enters the bleach or softner dispensers it runs over and leaks on floor. I've cleaned the outlets their clear. Seems too much water comes in to dispenser areas.
If the lines to the drum are clear and draining properly then you will need to replace the water inlet valve since it is allowing to much water to pass through to the dispenser. Here is that part to order. Whirlpool W10326913 Valve AppliancePartsPros com
Mar 03, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
this is joyce
thanks,
joyce
Feb 06, 2009 | Whirlpool Washing Machines
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
