Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 52WM48 - Dark line across top of screen about 4 inches
You can watch tv fine, however there is a horizontal line which makes the picture appear darker across the top of the screen, it starts about 1-2 inches from the top of the set and the band is around 4-5 inches high, can anyone help with the problem please.
  • aston_m Jan 25, 2009
    Thank you for your reply, we will keep the information and try the solution - you have certainly put our minds at rest, the problem isn't too noticeable at the moment, so we have time to source parts etc - thank you again.
Replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Posted on Jan 24, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 23, 2012 | RCA F32672SB 32" TV
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
