It keeps showing fault E09
SOURCE: Bosch nexxt 500 series dryer
I have a Siemens dryer and few days ago it stopped heating, but the drum rotates. The problem was because of a safety reset button that went off. On the Siemens (WT dryer series), it is a red button behind the dryer.
Press the red button and it will restart. I might have started a fire, if not for this safety switch.
A similar reset button must have tripped on the Bosch dryer.
FYI: Remember Bosch and Siemens share their technology.
SOURCE: My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
SOURCE: My tumble dryer (Bosch Exxcel) is showing an error
F09 error is no heating.
You can fix that by opening up the back and pressing the red cutout button which will restored hot air.
Good Luck,
I hope this helps
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
