Question about Frigidaire GL38LKEC (LP) Grill
How to replace main burner on frigidaire grill
I've removed the broken burner (right-most one) but am unable to fit the new burner into the front hole so that it lines up with the back of the grill where the screw holes are.
  • Shelly Jan 12, 2013
    The grill model # above was automatically filled in when i made this post. I am not certain but I believe my model # is FD27 (LP).
2 Suggested Answers
  • 10865 Answers
SOURCE: trouble removing gl38 burner
Hello Neal. Yes, the trick is to gently bend the tubes to remove them.
Posted on Jun 17, 2009
Coolant leak
It is possible that the housing for the water pump has corroded and the new(hopefully) gasket is unable to seal off properly. Water pumps have a bleed hole underneath before the bearing so that in the event of the seal leaking the water will run out and not affect the bearing. May be the housing was not cleaned properly and a piece of old gasket is preventing the new gasket for fitting properly. If you have doubts that he did the job go back and front him to get the job done properly. Remember that in future the replaced part is yours and you have rights in law to take the old part home with you to prove it was changed.
Jul 14, 2013 | 1997 Nissan Maxima
How How do I fix my broken water line that goes in to the freezer door to the water dispenser?
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
Freewheel lever broken
For the wire to come all the way out lever on top of the trans must be broken. I've seen a few. Jack rear of mower up, remove rear right wheel and find remnants of lever. With pliers turn this all the way forward, mower will now go. But to fit new lever trans will have to be removed. Dont forget the axle key.
Nov 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Front, back & side burners burn but center cross burner doesn't and flame is very low.
Many times this is due to build up on/in the burner itself or blockage in the gas line.
Most burners can be disassembled if you are mechanically inclined fairly easily. The gas grilles I have taken apart all fit together without using any fasteners, I think this is to provide easy cleaning.
If I was you I would try to remove the burner, usually the burner has a small pipe coming off of it which the gas line connects with, usually just a dry meaning there is nothing mechanically holding the gas pipes together. Removal usually consists of lifting the burner out of a mounting bracket and sliding the gas pipe off the end of the inlet gas pipe. Once removed you can check the gas pipe for obstructions removing any debris which may be accumulated there. Also check the burner sometimes the tiny holes around the burner get gummed up and using a toothpick can be cleared out.
If you want to be more drastic you can drop the whole thing in some oven cleaner, just be absolutely sure you have let all the cleaner dry/evaporate before you try to use the burner again.
...Hope this helps
Mar 12, 2011 | Weber Spirit SP-310 Propane Grill
How to instoll new hardware dvd rom
Turn your computer off.
Disconnect the power-cord.
Remove both the side-panels.
Disconnect the "data" and "power" cables from the back of the drive.
Remove the mounting-screws on both sides of the old drive.
Slide-out (to the front) the old drive.
Slide-in the new drive, aligning the holes in the sides of the drive with the holes in the sides of the case.
Re-insert the screws. Don't overtighten!
Reconnect the "data" and "power" cords -- they are different, so only fit only where they should fit.
Replace the side-panels.
Connect the AC power.
Turn the computer on.
Sep 30, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
How do you clean the un-removable burner tops
I have a MGR4452BDW. The burners turn 1/4 turn, then pull out. Yours should too.
Feb 23, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
How to open Iomega 650 USB CDRW
Remove the front cover.
Use thin screwdriver to pry side-locking tabs tward the center of drive.
Tabs are on both sides, near the front.
Also on both sides near the back, thru small access holes at the back, on the sides.
Comes right apart, no broken bits.
Feb 02, 2008 | Iomega Ext.DVD Id +/- Rw USB2.0 HD Burner
Frigidaire GL38LKEC (LP) Grill Logo
101 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
