Question about Jeep 2012 - Wrangler
Fuse for hazard flasher
Left flasher not working
    Sergeant:
  • 251 Answers
Why do you say fuse? The control unit for flashers is a relay switch these will fail at some point. When they do lights may not flash at all or may stay on continuously.
Posted on Jan 12, 2013
The turn signals don't work on a 99 Oldsmobile cutlass and the fuse isn't blown how can I fix
When the ignition switch is in the RUN or the START position, voltage is applied through the TURN/LPS fuse to the normally closed contacts of the hazard switch. A single flasher in the hazard switch performs the following functions:
• The turn signal operation
• The hazard flasher operation
When the turn signal switch is in the LEFT position, voltage is applied to the following components:
• The left turn indicator
• The left front park/turn lamp
• The left rear turn lamp
The lamps immediately turn on and flash as the flasher opens and closes the circuit. If a bulb is in need of replacement, the turn lamps will flash at twice the normal rate.
Without testing i would probably say the flasher is bad .
do the four ways work ?
Mar 02, 2018 | Oldsmobile Cars & Trucks
Turn singles and hazards are not working on my 2001 deville
I would replace the turn signal hazard combo switch.
Nov 28, 2016 | Cars & Trucks
My left turn signal recently stopped working. Before ceasing to work, the turn signal (just the left) would blink very rapidly (machine gun speed).
sounds like one of light bulbs was malfunctioning and caused the flasher unit to blink rapidly and iy burned out. Replace front and rear turn lite bulbs and see if flasher flashes. if not check fuse and replace fuse. If fuse okay replace flasher unit. Good luck
Jul 08, 2016 | 1997 Plymouth Voyager
The fuse for a right turn signal on a 2001 Buick Park Avenue
The left an right turn signals get there power from same fuse ,HZDT/SG fuse 15amp in the left under hood fuse box. through the turn signal hazard flasher module. Here is how they work .
Turn Signal/Cornering Lamps
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.The turn signal switch or the turn / hazard flasher module is bad or there is a wiring problem. Go to you tube an check out a few videos on basic electrical testing ,then get a DVOM - digital volt ohm meter , an wiring diagram an trouble shoot the circuit . There may even be a video on test turn signal circuit .
Dec 04, 2015 | Buick Cars & Trucks
Rear hazard flashers don't work 1994 Chevrolet Cavalier
Hazard flasher power comes from the 20A S/LP fuse in the fuse block. It is applied to the hazard flasher in the convenience center. Flasher output is applied to the turn/hazard/headlight SWITCH assembly where activation of the HAZARD switch causes flashing power to be applied to the turn indicators and the turn filaments of the front and rear dual park/turn lights. If replacing the fuse doesn't work, trace the power through the circuit. Check for misssing/disconnected ground wires.
Sep 16, 2012 | Chevrolet Vehicle Parts & Accessories
Hazard flashers do not work. Turn signals do. Changed relay. Nothing. Ugh. 1992 oldsmobile cutlass supreme
You changed the hazard flasher or the turn signal flasher? It has two, one for the hazard and one for the turn signals
Aug 31, 2009 | 1992 Oldsmobile Cutlass Supreme
Renault laguna 1.9tdi dynamique 51 reg. hazard warning lights do not work, changed fuse still not working. whats wrong with them
If your turn signals work, then replace the flasher for your hazards. Turn your key on then give a left turn signal. Listen for the "clicking" sound near your brake pedal and accelerator. Once you locate your turn signal flasher (small, "cylinderical", device) the hazard flasher should be near it. Simply pull out the flasher and replace... just plugs in.
Jun 07, 2009 | 2000 Renault 181
Turn signals don't work
i have a similar problem but my left signal works, when i turn the right on it just does an annoying buzz sound. if you can think of any explination for such shinanogins help would be greatly appreciated
Nov 25, 2008 | 1989 GMC K1500
Location of flasher for turn signal
  1. Access the COMBINATION Turn Signal and Hazard INDICATOR FLASHER on the Left-Hand (drivers) side of the instrument panel in the fuse junction panel.
  1. Remove turn signal flasher/hazard indicator flasher by pulling indicator flasher straight out.
  1. To install, align the terminals of the flasher and press into place.
How about a picture--
Oct 03, 2008 | 1996 Ford Thunderbird LX
Turning signal and 4-way hazard flasher not working
the actual hazard lights switch is also a relay and linked to signals left/right try checking this out ?
Aug 30, 2008 | 2000 Toyota Sienna
Jeep 2012 - Wrangler Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
