Sum err dvd player Panasonic - Televison & Video
When I try to record a dvd with timer or manuel it will not record, says err
Solution:
1. Not good DVDRW media blank
2. Open Panasonic model support page, click download software, Update Firmware
Dec 16, 2014 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd player wont play dvds
sir if it is out of warranty , you may open its top cover then carefully clean its lens by the use of cotton buds.,,. but be careful while cleaning it, cause if you don't you may damaged it.,
Jun 06, 2012 | Panasonic Televison & Video
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I cannot use it for anything while this is going on. Please...
what did u do? I have the same problem and I am hoping that I can still keep the speakers and replace the DVD. I called Panasonic and they said I shld take it to the nearest service center and they said no replacement. I dont want to buy a whole new system, what did u do?
Aug 18, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for...
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Jul 05, 2010 | Panasonic SC-PT960 Theater System with...
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
Panasonic DMR ES40V Err message, DVD won't play or record
I had a similar ERR message and freaked out a bit for a week. Panasonic customer service was no help and suggested i send it in for VERY expensive repair. No way. After tons of additional research and trouble shooting I fixed my unit tonight. I downloaded the DMR-ES40 DVD Recorder Firmware Update from the Panasonic update and stored in on a CD. Put the cd in my dvd player following instructions from the website. My system is restored and works well again.
Why paid personnel at Panasonic could not tell me this is beyond my understanding.
Try updating you firmware as I did. Hope you get the same success. -Tamara
Dec 11, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic says no HDD ERR
Is your HDD full? I've never had this error before, but then I've never filled my HDD either, so is this a possibility?
Oct 17, 2008 | Panasonic DMR-EH57 HDD Recorder Player
DVD Panasonic DMR E50 will not play. Has Hard err
According to the service manual, the DVD drive has a malfunction and needs to be replaced.
Jun 29, 2008 | Panasonic Televison & Video
Panasonic dmr ex75
HDD ERR is quite a serious error, as it means there is a hardware problem with the internal disk drive. You could try switching off the unit and disconnecting the mains cable overnight, and trying again, but really this will need to be a call to an engineer.
If your unit is still in warranty call them now to arrange a fix. To find your local warranty centre, go to your regional Panasonic website, and look under Customer Support
Nov 21, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
