Question about Microwave Ovens
Ge microwave clean glass streaks inside door window
Three streaks inside the glass of the door. They show from the outside. How does one clean this? Does the door come apart? Is it safe to disassemble the door?
  • 1462 Answers
SOURCE: Microwave oven glass window on the door
do not use - there is a possibility of microwave leakage.
Posted on May 07, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Posted on Jun 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
Posted on Jul 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 19, 2008
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
Steam got inside door of microwave behind glass. Now there are white spots where water dried. How do I clean the inside?
Look and see if there are screws holding the inside of the door to the outside of the door.
If so, remove the screws and the door should come apart, and may be cleaned.
God bless your efforts.
Jun 29, 2010 | GE HVM1540SNSS Microwave Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
GE XL1800 Door
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
