Question about Samsung Audio Players & Recorders
Samsung HT-C555 5.1Ch disc tray will not function
4 Suggested Answers
SOURCE: Unlocking Disc Tray?
There should be an access hole under the unit where you can move the load/unload mechanism manually.
Posted on Dec 04, 2008
chipsandnuts
  • 70 Answers
SOURCE: Samsung HT-X20 disc tray won't open
while unit is unplugged, try holding down the power button on the main unit for 10 seconds.
Hope this helps!
Posted on Jun 30, 2009
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
Posted on Nov 23, 2009
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
How do i change my region on my samsung HT-E3500 i am in mexico and can't view my dvds from the states
tengo la misma pregunta , lo he comprado en el palacio de hierro y no pudieron hacerlo multiregion , lo llevare a un centro de atencion a clientes , si se algo te paso el codigo o, o si tu lo sabes antes me lo pasas . Saludos
Nov 10, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
Samsung HT-E3500 region-free
I have a new HT-E3500, and after 20 minutes I got the following to work.
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running 080604.01_050708-1_XSA code.
I used the R4 code from below.
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now it to me about 20 tries to get this to work, It needed to be done without delay.
So if you don't get it to work straight away don't loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jul 02, 2012 | Samsung HT-E3500 - Home theater system -...
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
Hope this helps!
Jun 23, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Playback problem with Samsung HT-TZ315
your case open /close tray unit having problem
1.disasample the tray unit and reasample it 2.also check tension of belts and clean tray unit properly
2. check for any physical damage "s
try all the above you solve the problem.
Oct 15, 2008 | Electronics - Others
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
32 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
