Question about Sony Ericsson T707 Cell Phone
Sony ericsson died and wont switch on
MY PHONE JUST DIED AND WONT SWITCH BACK ON DESPITE REPLACING/CHARGING BATTERY. REMOVED SIM AND CLEANED ALL TERMINALS
  • 3 Answers
It's likely that you need to reflash the phone software to your phone. You can do this yourself [detailed instructions and files at se-nse.net] or just do it at a phone shop or through an online site like Da Vinci or Wontan.
But something you should try is to remove the battery and take out your SIM / memory card and then let it sit for a bit before you reinsert the battery [withouth SIM / memory card] and restart the phone. Hopefully that'll work, if not then you'll probably have to reflash the phone software. But you could always check by doing a software upgrade using SEUS [Sony Ericsson Update Service offered for free here - http://www.sonyericsson.com/cws/support/...
Posted on Jan 12, 2013
5 Suggested Answers
ghetto0802
  • 6 Answers
SOURCE: sony ericsson W901i wont charging
replace the plug in of the fon..it cost about RM30
Posted on Jul 10, 2009
seanpwright
  • 2030 Answers
SOURCE: my sony ericsson w980 just
If it wont switch back on, then there is not much hope for it. Take it to the carrier that it came from and maybe they can fix it, or at least get it to turn on for you.
Posted on Aug 01, 2010
AnnamMaha
  • 106 Answers
SOURCE: sony ericsson K750i phone died during update
I think are using sony Ericssin PC syn.This it will cause some problems.There is a separate software for updater, download it and follow the process given in the site.this should work.
Posted on Jun 04, 2010
Testimonial: "thankyou for help and very quick response "
SOURCE: hi i have a sony ericsson vivaz u5i. My phone wont
use repair fonction on sony ericsson pc suite
Posted on Mar 24, 2011
Sony xperia x10 went dead wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
I was trying to reset to factory settings so pressed and held in power button and the square in the middle on front of phone now it wont turn back on
Try the following steps
  • Leave your phone charging overnight
  • First remove the SD card and try to switch it on, if not then remove the SIM card as well.
  • Remove and re-insert the battery firmly.
  • Try to download the update from here.
Jul 03, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My sony ericsson w980 just froze and died. it wont switch back on. can i fix it?
Aug 01, 2010 | Sony Ericsson Walkman W980i Cellular Phone
Sony ericsson W901i wont charging
listen whereu part the charger pin that is damge need to replace that part then it will be work
Jul 07, 2009 | Sony Ericsson W910i Cellular Phone
It died and now wont turn back on
maybe if you restart your zune?
if so u To restart the Zune device, follow these steps:
Collapse this tableExpand this table 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button Collapse this imageExpand this image zune_button_back.gifwhile you press the top of the Zune pad.
Mar 25, 2009 | Sony NWZ-E438F Digital Media Player
Hi, my sony ericsson k850i keeps switching itself off, and now I cant get it to switch back on. I have removed battery, sim, tried charging etc, all with no luck.
you need to take the phone to a mobile service center and have them reflash the phone to get it bak working for you.
Nov 01, 2008 | Cell Phones
Charging
Try putting it on charger and switch on the phone. My guess it that the charging mechanism has gone bad in the phone. also try charging the same battery on another phone which uses the same battery (if you can) this will tell you if hte battery is alright. Also try replacing the charger (just in case).
with the charger plugged in, try connecting the phone to the computer and take back up. also some of these phone (i am not sure about your model charges when connected to Computer. try that as well..
take care.
Jun 20, 2008 | Sony Ericsson Walkman® W880i Cellular...
K750i Not switching on when charging the infrared port glows
hello
i have the same problem with my k750i, without any damage or accident it went off, and thereafter i could not switch on despite several attempts. The battery is fully charged and the sim works with other cells. there is no any sign and the phone is compeletely dead.
Please advise me
Thanks
Apr 06, 2008 | Sony Ericsson K750
Sony ericsson k800
try flashing(update software) the phone. does not require phone to be on. go to sony ericsson home website, on the page youl find the link (update software) download it. open the file and follow the instructions,(you will need a a sony ericsson transfer cable) updating the software will delete things on your phone ,take out ur sim b4 doing this.
Apr 02, 2008 | Cell Phones
Sony Ericsson T707 Cell Phone Logo
114 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
