Question about La Crosse Technology LaCrosse Technology TX6U 433 MHz Wireless Temperature Sensor
TX6U thermistor value
The thermistor is broken, before I throw it out, want to try soldering in a new one, but need the value in ohms, These glass type vary in values from 2k to 2m ohms.
Fridge doesnt cool enough ,have slide all the way up doesn't seem cold enough
Open the outside vent to gain access to the back of the refrigerator. Located at the lower left is a black cover. It will have a screw in the center top. Remove the screw then using a flat tip screw driver release the lock tabs located on the lower left and right so that you can remove the cover. Once the cover is out of the way you will see on the left side of the circuit board two different harnesses plugged in. One will have four wires the other will have two wires. Unplug the two wire harness, this will disconnect the thermistor and also put the refrigerator in wide open mode. You will need to test the thermistor. This is done by removing the thermistor from the plastic clip on the inside of the refrigerator and submerging the tip into a glass of slush or ice water. Then go out side and with a multimeter, measure the ohms between the two terminal of the plug end, inserting the multimeter probe from the back side of the plug, you should read between 7k - 10k app ohms. There is a chart that you can lookup online that will give you the values of ohms/temp for the thermistor. If the range is not in spec then you need a new thermistor. If it is in spec and the temp does not drop with the thermistor unplugged then you have a cooling unit problem.
Jun 17, 2014 | Dometic RM2852 Refrigerator
Viking vuim150dlss bin t.mister
Do you have a new one? Try comparing the values. There are several types of thermistor. Do you have the type number?
Mar 16, 2014 | Ice Cube Maker
GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
your thermistors are way out of range even at that temperature you say,put each thermistor in a glass of ice water for 5 minutes,then remove the J1 connector from the main board and check with an ohm meter set on 20k ohm between the thermistors common terminal #5 and the other pin terminals all thermistors tested this way should be about 16k ohms when tested this way,if not replace them
Feb 11, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
The dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Nov 23, 2009 | Cell Phones
Hobart grinder mdl 4346, what is the value the control board is looking for on 1QTM and 2QTM? Is this a resistance (thermistor) and if so, what is the value? We had the motor re-wound but could not...
It is a thermistor and the value should be approximately 100k ohms at room temp.
You can substitute a pair of 100k ohm resistors to allow operation but to actually get the protector board to function as designed you will need the ~100k ohm thermistor with the correct temp / resistance curve bonded into the stator.
An option would be to use a standard motor starter for the protection although the wiring gets a bit tricky with the relays, aux switches and the reversing contactor.
Another option would be to imbed / affix a klixon type overload into the windings and wire this in series with your 100k ohm resistor.
This will still allow the board to indirectly protect the motor.
Oct 26, 2009 | Hobart Food Processors
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
La Crosse Technology LaCrosse Technology TX6U 433 MHz Wireless Temperature Sensor Logo
57 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
