Question about EnGenius Esr-6650 3g Mobile Wireless Access Point , Soho
EnGenius firmware upgrade failure
I upgraded the application software before the kernal software. Now all I can get is the flashing power LED. Is there some way to set this to factory default? Neither wireless nor Ethernet cable will allow me to access the router. Please help. Thanks, Tom
2 Suggested Answers
SOURCE: After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
Posted on Jun 01, 2008
I WOULD LIKE TO UPGRADE THE FIRMWARE ON MY SONY KDL40EX400 LCD TV.I BOUGHT THE ?FLASH DRIVE FOR IT. HOW DO I DOWNLOAD THE INFORMATION ON TO IT?
You must go to the Sony website and answer the questions about your TV. Model number etc. Then go to support and input your model again. Look for software/firmware upgrade and it should take you to the firmware upgrade and download for your Model number. Download the firmware upgrade "INSTRUCTIONS and the firmware to your computer. Then plug in a blank formatted USB flash drive into your computer and transfer both the instructions and the firmware files to the flash drive. Be sure to unzip the firmware files on the flash drive. Print the firmware upgrade instructions so you can have them there when you are ready.Special Notice!!! Read and really understand the instructions and follow them to the tee. Do not power off the TV or unplug the flash drive while the TV is upgrading the firmware. Let the TV finish.
Nov 11, 2017 | Sony Televison & Video
Wrt 54gs ver6 power led flashes rapidly all other leds off. if lan is plugged in..the led comes on.. hard resetting does not bring the router to it`s original state either.All this uooured when i had a...
This power failure could not have happened at a worst time.
Try reinstalling the upgrade again, and if this does not fix the problem then I think you have a piece of junk.
Mar 30, 2012 | Linksys Wireless-G WRT54G Router
My ZyXEL p660 router after being reset will not power up properly anymore the power led flashes green and the wireless light stays on after about 15 seconds the powers led stops flashing and turn off...
You will find ADMINISTRATION tab in the upper right hand corner.
click on the administration tab. just below the administration tab you will find firmware upgrade sub tab. Click on Firmware upgrade.
Now on this window you will find browse option. click on the browse button and select the firmware file that you have downloaded on the computer. after selecting the proper file click Upgrade. The upgrade process will start.
It may take 2 to 5 minutes.
once you upgrade the firmware of the router, unplug the power cable of the router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router Upgrade
# Click Browse and find the file you just downloaded.
# Click Upload. Do not interrupt the upgrade while the router does this step.
For Belkin router
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page.
The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Jan 19, 2011 | Computers & Internet
Service call 05H,for konika minolta magicolor 2490MF,konika minolta printer
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
Aug 07, 2009 | Konica Minolta Office Equipment & Supplies
Won't boot up and not recognised when connected to PC
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Flash my nokia 3230
first give "restore factory settings" you will asked for the "security code" enter that .. after "restore factory settings" you restart the phone without memory card ...
connect the mobile to pc by using datacable
if you still face the problem after the " restore factory settings" then
you can upgrade the firmware by downloading the "nokia software updater" from the nokia site given below it is free
http://maps.nokia.com/A4579163
first you must download that application to pc and then you must the cell to pc and then you can upgrade the firmware of your cell ...
NOTE:never disconnect or power off during the firmware update this willdamage your cell phone completely and after that even if you visit thenokia also they cant help you with that , so while doing that do itcarefully ..
Sep 05, 2008 | Nokia 3230 Cellular Phone
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
EnGenius Esr-6650 3g Mobile Wireless Access Point , Soho Logo
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
