Question about Husqvarna 120, 125, 132 Trimmer Ignition Coil Module 531002395, 531004731
Plug does not spark, wil not start.
I assembly a 132R but their is no fire going to plug. Did I put coil wrong in or is their something wrong with wiring. Do you a drawing about it.
  • Husqvarna Master
  • 2,239 Answers
There is very little wireing to get wrong on this machine however diss connect all the wires from the unit, set the air gap between the unit and the flywheel to 0.3mm and crank the engine with the plug out and earthed against the cylinder, do you now have a spark if no then it is a bad unit, if yes the wireing to the switch is bad, or the switch itself is bad.
Posted on Jan 13, 2013
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
Spark plug wires
each plug wire will go to coil pack. coil pack is numberd as to what wire goes where. rear bank towards fire wall will be plug #1,3,5, front will be 2,4,6
Apr 14, 2013 | 1999 Dodge Caravan
1993 Nissan 300zx: Number 4 cylinder doesnt fire.
Please read about misfire diagnosis and repair here.
Oct 01, 2012 | 1993 Nissan 300ZX
1993 honda acord wont start there is fuel going to the intake but wont start and if i tried to put fuel directly in the intake tried to start to wath can i do ???
Did you check the spark? Pull a plug and reconnect it to the wire and lay it on a piece of metal away from the piston hole, (flame thrower) And click it over to see if it sparks. If no spark, you have a bad coil or coil pack. You should be able to find one in a junk yard, don't go out and buy a new one, it could be something else. Like low oil, fuel pump, ignitor, etc. If it sparks, squirt a little fuel into the spark plug hole and fire it up and see if it fires that way. Have to narrow this down to something. Check it out, hope this helps.
Mar 02, 2011 | 1993 Honda Accord
Ok i recently changed spark plugs on my 1994 buick skylark. when i was done changing plugs i started car up and smelled strong exhaust smell. so i checked the plugs wires and found out that when i pulled...
Did you mean coil the 1994 3.1 did not use a distributor , sounds like a bad coil pack and cylinders #3 and #6 do use the same coil. I would also check 3 and 6 plug wires this system is a waste spark design meaning when # 3 coil fires it is supposed to go through #3 plug wire , through #3 plug ( ground) through the engine block through the #6 plug then through the #6 wire then back to the coil, Then when #6 fires it works the opposite way, so in theory you could have one bad wire affecting 2 cylinders .....
Dec 20, 2010 | 1994 Buick Skylark
Had sparks from coil, bought new coil same problem, bought new distributor, now car will not even start
By distributor, is that the cap or the whole piece of aluminum- housing with stator assembly/ control module/shaft/rotor/cap, the whole sha-bang.
If it was the "whole" distributor & If it ran before you put the distributor in & you only had sparks then the distributor was installed wrong.
Check for spark at the end of the plug wires. If you have spark then its more likely the distributor is in wrong &/or the firing order is off.
Sep 18, 2010 | 1987 Chevrolet Camaro
2004 KIA OPTIMA WON'T START AFTER SPARK PLUGS WERE CHANGES
HI. There are several areas of concern here. I will list them below. Check all areas stated in the list for faults.
Possible cuases:
1. Incorrect firing order set. On the 2.0, 2.4 and 2.7 engines. These engines are equipped with a distributor-less ignition system. This system incorporates a coil pack assembly, along with wire sets. In order for the assembly to fire correctly, the order of the wires must be set to the proper sequence. if not, the engine will not turn over, or start correctly. Make sure your firing order is correct, and make sure you have not placed a particular wire set into the wrong cylinder. I will post a picture of the correct firing order for your engine, below this list, shortly.
2. Incorrect spark plug gapping procedure. If the new spark plugs were gapped incorrectly, this will not allow for proper spark, thus, preventing optimal combustion, due to lack of fire. Check the spark plug gap using a wire gap gauge, and adjust if necessary. The gap should be 0.039-0.043 in. (1.0-1.1mm)
3. Failed coil pack assembly. This will be the worst case scenario. The coil pack supplies the necessary current that fuels each plug. The current is transferred, via wire sets.This will be the culprit if all the above areas are proven to be operational, and in good shape.
4. Failed wire sets. Replace the wire sets if faults are found at the connector at the ignition coil pack, or at the plug boot.
NOTE*
In order to provide the correct firing order for your engine, i will need the engine size and liter information, if possible. Please post this information, asap. Thanks..
Mar 24, 2010 | 2004 Kia Optima
I have a 1990 fxr with a single fire ignition, cam and s&s carb. I am not getting the rear cylinder to fire. I just cahnged the coil but no change. I have compression out the exhaust pipe for the rear...
With a single fire ignition, you cannot swap the wires. A dual fire ignition, yes, but not a single fire. You need two things to get the cylinders to fire, spark and compression. Take the plugs out of both cylinders. Run a compression test on the rear cylinder. You need at least 100 PSI to get the cylinder to fire like it should.
Next, put your plugs in the wires, (they should already be in the wiresand grounded) and spin the engine over. Watch for the plugs to spark,especially the rear plug. If you have spark and compression it should run on the rear cylinder. If it still doesn't run, either something is way wrong with the ignition or a very bad air leak on the intake.
If you don't have spark at the rear plug, you need to check the coil. A single fire coil is different from a dual fire coil. The primary wiring is different as well. If you've got the primary wired incorrectly, you won't get spark at the rear plug. Go to the website of the manufacturer of your ignition system. Most of them have downloadable installation instructions. Check your primary wiring.
Oct 02, 2009 | Harley Davidson FXDL Dyna Low Rider...
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
Starting and stay running
Hey,
The 'wire to the coil' that you mentioned could be the problem! (They ain't meant to be taken apart.)
You see, these things are built and operate as a unit, and must be replaced as such.....
Go to a bike wreckers (dismantlers) and source yourself another coil and spark plug lead assembly and refit.
Then, as long as you have a good battery, spark at the plug, and fuel, the old thang should fire up and run OK......
Good luck, mate....you've got a groovy little bike there. :oD
Jun 01, 2009 | Honda CB 100 Motorcycles
Husqvarna 120, 125, 132 Trimmer Ignition Coil Module 531002395, 531004731 Logo
98 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
