Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
Lg Washer Dryer Combo filling with water on dry cycle
Washer works fine then the dry cycle kicks in and the tub fills with water. The pump works fine for the wash cycles. I need to run drain and spin after the dry cycle to even open the door without water spilling out,
3 Suggested Answers
  • 13 Answers
SOURCE: water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Posted on Apr 11, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a LG Tromm
Hello & Welcome to FixYa
I believe the problem is with the sensor switch assembly that needs replacement as when pressing SPIN SPEED and SOIL LEVEL at the same time after draining the water level frequency needs to be 255. And when pressing SPIN SPEED and SOIL LEVEL buttons at the same time while washing the water level frequency should be between 230 - 243. If it is reading this then it is the main power board that needs replacement, though I don't know if that is the board that is already replaced or if it is some other board that has been replaced. You can also check this repair manual if you want to do this repair yourself. Please get back to me if you have any other questions.
Kevin
Posted on Jun 20, 2011
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
LG WM3988HWA water filling drum and overflowing during dry cycle
Solution for finding the right part, the (5 way) Valve assembly:Part Number: AP4998623 made by LG
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520795
I got the company link from LG. If the link does not work, go the the main website and enter in the model number. appliancepartspro(.)com
p.s. I found a service manual for my unit when I removed (by unscrewing) the inside plastic piece of the pump filter. It was located to the right, in a plastic bag.
p.s.s. I checked my water pressure, it was 90psi. I think this is why my flow limiter 'shot out' the valve and into the tubing.
p.s.s.s. The dryer heater assembly, the duct out, fan, and tubing was filled with so much lint, I was surprised anything could get through.
Nov 20, 2011 | LG WM3988HWA Front Load Washer / Dryer
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer/Dryer
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for drying..it also cools drum..
Dec 16, 2008 | LG WD-14124RD Front Load Washer / Dryer
Drying problems
This usually indicates that the fill valve for the drying cycle is faulty. In short you need a new cold water valve assembly. (this will fix this issue 90% of the time) Otherwise you may need a new control board.
Inside of the machine (you will have to remove the top cover from the machine) is a valve assembly attached to the cold water line. This valve assembly consists of 2 or 3 individual valve bodies . The one on the right hand side of the assembly usually controls the cold water inlet for the drying cycle(this is necessary for proper condensation drying to take place). There is a black hose which attaches this part of the valve assembly to the wash drum. With the water shut off and the power removed from the machine, remove this hose from the valve and look to see if it has a small red (usually) plastic insert. This is a restricter insert which limits the water flow into the tub. Without the insert the tub will fill with cold water in a short amount of time.
Aug 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
