Question about Bella Kitchen Appliances - Others
My bella deep fryer does not turn on.
When I plug into the fryer and then plug into an outlet the fryer does not turn on. The last time I used it the pug connecting to the fryer kept falling off or going from green to red. It appears i cannot get a good connection.
  • 3 Answers
SOURCE: Rival 3-L Cool Touch Deep Fryer
It sounds to me like it could be one of two things.
Either the magnetic cord safety thingy came slightly undone (which happens to mine constantly) or you didn't turn the timer to "always on".
The thermostat itself does not turn the heating element on, you must turn the timer to always on to preheat the oil, then when it's heated you can set what time you want to fry for.
Posted on Nov 18, 2007
  • 3 Answers
SOURCE: GE 106789 Cool Touch Deep Fryer
called Rival,they have loads of MDP-1 power cords sets,just purchased mine today.(1800-323-9519).BTW,,When asking ,its listed as MPD-1 instead of MDP-1,(typo error).Its the same cord.
Posted on Jan 23, 2008
SOURCE: Deep Fryer Element Won't Heat Up
i got this fryer for christmas and cant find the reciept i have used it four tiomes and now the lights wont come on and wont heat up i have tried other outlets and it still wont work what can i do?
Posted on Feb 26, 2008
SOURCE: Bravetti Deep Fryer Model F1053B Not getting Power anymore
Hey guys I fixed my problem...yay. All I did was to push a red button which I beleive is a resset button on the back of the on/off button part. It ain't visible but if you look in the holes of the screws that hold this part together (they are far down in the hole) one of them hides a small red button. Push it down with a toothpick or anything small enough to fit the hole and you're done. Plug it back and it works.
Posted on Jun 30, 2008
  • 43 Answers
SOURCE: fryer not working
I also have the 4320 and my problem was a reset button on the back, down in a hole.
My reset button is red. Also there is a safety swith on the rear where you slide the control
unit into the grooves, it has to be all the way down for it to work.
Posted on Jul 04, 2009
Why doesnt my deep fryer heat up ?
First it is good to check the fuse by unscrewing the plug.
If the fuse wire is not broken, it means that the deep fryer could be broken.
Nov 21, 2015 | Farberware Home Electric Faberware Deep...
Unit is not turning on or calling for heat, why?
sounds like the elements have opened check with an OHM meter
Mar 23, 2017 | Cecilware EL2X15 Deep Fryer
My ge deep fryer will not turn on
If your fryer uses the DP16 cordset, this is probably your problem. If not, find and press the reset button.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
May 15, 2010 | GE 168952 Deep Fryer
Most of these fryers have trip on the rear of the element unit. Search for the trip and reset, if this does not sort out your problem check the fuse in the plug if you are in Europe.
Regards
Alan Hood
ami-man
Mar 29, 2010 | GE 168952 Deep Fryer
Cord gets very hot on the outlet side, prongs will cause 2nd degree burns if touched, made outlet very hot as well.am certain it will cause fire inside wall if left on to cook with.
flyindawgs -
The unit is pulling more current than the outlet can handle. The unit runs at 1500Watts, or uses 12.5 Amps of current. Most outlets are rated for 15 Amps. It's likely that you have other outlets that also have devices plugged in to the same circuit. For example, having two or three outlets in a kitchen that are all on the same circuit, you might have more than one device running, and exceed the 15 Amps the circuit is made for. So, even though each outlet might handle 15 Amps on it's own before burning up, it's the total amount of current on the circuit that is the limiting factor (3 kitchen outlets wired together on a 15 Amp circuit can have any combination of devices plugged in and running at the same time, as long as the total is less than 15 Amps).
Having a cord turn warm or hot when in use is always BAD. You should try running the unit without running anything else on outlets in the kitchen. See if it still heats up the cord. Do not leave the unit unattended, and do not let it heat very far. Just turn it on and see if it starts to heat up. If it doesn't, you just have to make sure not to use other devices while frying, and you'll be fine (Running a 12.5 Amp device on a 15 Amp circuit normally would not be a problem).
If it does, there is a problem with the fryer or your household wiring. One of these two is compromised in some way (like a partial short or loose wire connection). Do you know anyone who can measure the current use on the fryer for you? Someone familiar with electricity should be able to help. Hopefully, the fryer is bad (using more than 12.5 Amps means it's got a problem), and not your wiring. If the fryer checks out okay, then your wiring is to blame, and you can't use the fryer on that set of outlets. That kind of leaves you out of luck, as I suspect that you don't want to deep-fry in the living room or the garage.
If the wiring is at fault, an electrician can fix the problem by re-wiring or adding more capacity to the circuit, or adding another separate circuit that you can safely use the fryer on. These are expensive solutions, so you may choose to simply do without the fryer. With luck, the fryer itself is malfunctioning, and replacing it will solve your problem.
Thanks,
videoman7
Aug 14, 2009 | Hamilton Beach 35030 Deep Fryer
We bought the fryer in April, have only used it four or five times but have been very happy with it. Yesterday when we turned it on the light did not come on nor would it heat up. The connections seemed...
Change the internal fuse if blown(or the circuit breaker my be reset). The wire shoe can also be faulty, you can replace with another one.
Note: The shoe is the thing at the end of the wire which you plug into the electrical outlet.
Jul 30, 2009 | Rival CZF530 Deep Fryer
My fryer won't do a thing
there is a shut off swich and if you dont slide it into the deep fryer part correctly it wont turn on or do any thing the other is to make sure the breaker in the back of the unit is pushed in
Dec 01, 2008 | Euro-Pro F1066 Deep Fryer
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
kstfas
Oct 07, 2007 | Kitchen Appliances - Others
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Kitchen Appliances - Others Logo
1,303 people viewed this question
Top Bella Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
richie46
ray gallant
Are you a Bella Kitchen Appliances - Other Expert? Answer questions, earn points and help others
