Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not start
Washer has nothing on screen, only light up thing is control lock?
    President:
  • Whirlpool Master
  • 662 Answers
Press & hold down the 'end of cycle' signal button at right end of panel, till the control light goes off, usually 3 seconds. This is the child lock feature. Do it again and it locks.
& rate me pl................4 thumbs
Posted on Mar 28, 2013
SOURCE: Control Locked
you have to push a button on right side which tells you to hold down this button for control lock
Posted on Sep 28, 2007
bestdarngood
  • 3037 Answers
SOURCE: control locked
It is recommended to try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Let me know how this goes and whether you need any further help
good luck and please let me know if you have any questions when doing this
Posted on May 22, 2008
  • 1028 Answers
look on consoles for small lock emblem hold that button down 3-5 secs
Posted on Sep 03, 2008
jsrock516
  • 5911 Answers
SOURCE: i have a control lock light on and cannot start or unlock machine
The Control Lock is a designed safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Posted on Feb 18, 2010
richroth
  • 9472 Answers
SOURCE: Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Posted on Oct 25, 2011
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Dec 01, 2017 | Maytag Centennial MTW5800TW Top Load...
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Sep 01, 2008 | Whirlpool GHW9200L Front Load Washer
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Control Locked
Sep 14, 2007 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
