Question about Timex Ironman Watches
Heart rate not showing on watch - Ironman Timex Watches
  • 248 Answers
It is probably that your heart rate sensor is out of battery power... try to change a new one. hope this will help..
Posted on Feb 06, 2013
escapement
  • 2334 Answers
SOURCE: replace battery in my Pola F11 Heart Rate watch
Yes, your watch will retain the same water resistance if you will not damage the rubber gasket. After replacing watch battery, clean that rubber gasket with lighter fluid(ZIPPO), place back in watch exactly as it was before and reassemble the casing.
If there are screws on caseback, do not overtighten them. At the same time do not leave them too loose.
Memorize how much power you needed to unscrew them and use the same to screw them back.
I'm recommending ZIPPO, because it would be difficult for you to get special cleaner and grease for gasket.
After cleaning the gasket with ZIPPO, rub a little bit of vaseline in to your fingertips and slide the gasket through them. That will do a good lubrication.
Don't forget to rate, please.
Posted on Jan 11, 2009
  • 2501 Answers
SOURCE: Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Posted on Jan 27, 2010
Testimonial: "thanks :)"
SOURCE: how to turn on the heart rate mode of solo 915
Please make sure you are in time mode. Now hold your bottom right button in for 2-3 seconds. You will see a heart pop up over the seconds. Now you will be able to take your heart rate.
Posted on Feb 02, 2010
escapement
  • 2334 Answers
SOURCE: Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Posted on Apr 14, 2010
Coachphil
  • 347 Answers
SOURCE: I have a Polar F11 Heart Rate Monitor. The watch
There is a step by step guide in my tips and tricks of things to try with your strap. If none of these work and you are getting a signal from another source then you need to get either a new strap, a new sender or both. If you send the T-31 wearlink into polar they can run a diagnostic and see which is bad and sell you just the piece you need or a whole new chest piece.
Posted on Dec 16, 2010
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
My watch does not show heart rate
I have a problem solving checklist about getting Heart rate readings in my tips and tricks page that may be helpful.
#1) you have to make sure the strap is across your chest and contacting the skin directly
#2) you have to push the button on the front of your watch to turn it on.
After that it should read automatically, there is no trick to your watch.
Jan 04, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
How do you turn the heartrate monitor on?
How do I turn the Heart Rate function on and off on my watch? Within the Date and Time screen, if the heart icon is showing, the heart rate function is on. To turn off the heart rate function, simply hold the Reset button until the heart icon goes away.
Aug 14, 2010 | Sportline C9 by Champion Fitness 910 Watch
The heart rate function does not work.
I got mine to start working by turning it on/off. This is done by pressing the top right, bottom right, and bottom left buttons for 5 seconds.
Jun 08, 2010 | Sportline SOLO 915 HEART RATE WATCH
Lost manual Sportline heart rate watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals. Rate me, please.
Feb 26, 2010 | Sportline C9 by Champion Fitness 910 Watch
Jan 27, 2010 | Watches
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
Watches Logo
59 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
