Question about Kohler K 304 Rite Temp Pressure Balancing Valve
Slow trickle From Bath Spout After Replacing Kohler Mixing Valve
I replaced the 304-K mixing valve for my Kohler Forte shower set. After turning the water on, it mixes as it should, but when turning the stem to full "OFF", there is a steady trickle of hot water continuing to pour out of the spout. Any ideas?
  • 1 more comment
  • Ange Jan 12, 2013
    I did not replace the brass assembly... Just the two black parts within the unit
  • Ange Jan 13, 2013
    Hey D. Floyd Kolb. How about chilling it with the canned, automated responses?
  • Ange Jan 14, 2013
    I removed the assembly and found that one of the two o-rings on the mixer that seat against the rear supply outlets of the housing had fallen out of place. Problem solved.
3 Suggested Answers
  • 653 Answers
SOURCE: Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Posted on Mar 15, 2009
agent91
  • 2100 Answers
SOURCE: replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Posted on Feb 28, 2010
I just installed a Kohler Forte R10412-N-CP. Hot water flow is good. However, very low cold flow. What's wrong
First turn off the shut-off valves and remove the Forte faucet inlet hose from the cold water line. Then put a temporary inlet hose on that shut-off valve. Test how much water flows into a bucket when you open the valve. Assuming that you had good flow from the cold water shut-off valve through the supply hose, a trickle flow on one side suggests the cartridge plunger (mixing valve) or the inlet hose is blocked or damaged. Since this is a new unit, I'd recommend you replace the faucet. The best option may be to take it to the place where it was purchased (depending on the return policy).
I hope this helps and wish that I had better news for you.
Feb 06, 2015 | Kohler Plumbing
Shower mixing valve shower comes on wit tub
If there is a button on your tub spout, replace the tub spout. If there is a button on the valve itself, replace that.
Apr 30, 2014 | Home
Kohler shower valve trim on temptrol mixing valve
all mixing valves are the same if you have one in you can change the guts or you can install a new one in a different location i have allways installed them at the hot water heater it makes things easy to service or replace
May 23, 2012 | Plumbing
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Sep 12, 2010 | Kohler Plumbing
Water start leaking under the house when you pull the deverter up to turn the shower on, its floods out bad!
I'm assuming the leak is in the wall somewhere between the on/off lever or knob and the shower head. It is a good chance that it is the mixing-valve. It could also be where the shower head screws into the drop-eared 90*. If it is the mixing valve, it is either ruined, or a bad seal that might be replaceable. If it is busted piping the wall will have to be opened up to replace it. Good chance that the arm to the shower head is leaking at the threads where it screw into the wall. Good luck.
Mar 15, 2010 | Delta RP17453SS Standard Diverter Tub...
Replaced shower valve. still drips from tub spout
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Mar 15, 2009 | Kohler Home
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Kohler K 304 Rite Temp Pressure Balancing Valve Logo
65 people viewed this question
Top Kohler Welding Tools Experts
Bill Boyd
Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
