Question about Samsung LN-S4692D 46 in. LCD HDTV
When i turn tv off i hear scraping noise loud like a fan
47' samsung tv
  • 98 Answers
It looks capacitor sound on Power Board.
need to replace power board
Posted on Feb 09, 2009
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Jun 09, 2010 | Samsung HCL4715W 47" Rear Projection...
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud noise when Tv comes on souns like fan.
The loud noise is the color wheel winding down when you turn the TV off. You need to replace the color wheel.
Nov 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP TV is making a buzzing sound. Sounds like something spinning. Can hear it speed up to full spend when turned on and slow down and stop when powering off the TV. Loud at times.
More than likely this is the cooling fan. I have a Samsung DLP myself, and at times, I can hear the fan running also. There could be something wrong with the fan, but I kind of doubt it. Just make sure that the TV is in a spot with lots of ventilation....otherwise, you might have to live with this noise.
Hope this helps!!
Chad
Oct 08, 2008 | Televison & Video
Loud poping noise
It sounds like the popping noise you heard was a capacitor blowing its top somewhere in the tv. Sorry I cannot be more specific but if you manage to find out where this cap has gone also check any resistors near it as they can be also damaged. If you cant do this call out a competant technician. Good luck.
Jul 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung LN-S4692D 46 in. LCD HDTV Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
