Question about Cobra 29 LTD CB Radio
Antenna light stays on
After tansmitting
    New Friend:
Check your standing wave with a meter (not the one on the radio they are junk)if you are under a 1.5 swr then open the radio find vr-6 audio the radio adjust it untill it goes off,if you are going to run a kicker turn it all the way off.
Posted on Jan 20, 2013
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
Ldv pilot key transponder antenna problems
not at all , check your battery first and if good ,try electrical switch.
unless you have green security light that stays on
and than the key will have to be re-programmed
Feb 23, 2014 | Cars & Trucks
Accelerator pedal sensorsmercedesbenz
run fault codes and check for torque convertor clutch solenoid/ servo and TCM
Jan 07, 2014 | Mercedes-Benz Cars & Trucks
I have a cobra 29 ltd the red antenna light was coming on replaced the coax with 18' coax have Wilson 2000 antenna calibrated radio red light still coming on and and swrs not staying consistent when...
Best way to locate the problem is connect the radio to a Dummy load known to be good====if swr still comes on it is in the radio--if not in the antenna system.
Apr 28, 2012 | Cobra Radio Communications
Extndedmods done not problem tansmiting in am radio go back to 10 meter or they do not here my voice clear or a load nois lake a long roger bit or does not trasmit ad all i have to reset again no...
make sure NO ONE clipped your modulation limiter!!!! the Magnums are way over modulated of a radio. any mods will cause trouble. you are probably getting a feedback making it sound like a roger beep.. also it will depend on your SWR's make sure they are good on the band that you are talking on. ie.. no antenna on the market can work 10-12meters except maybe the 108"whips $17.99 and the predator 10k.... so be sure to check the swr's on ever channel that you would operate on. like ch 19 and 28.xxx and be sure first. high swr's will cause feedback on any radio.
Feb 23, 2011 | Magnum OmegaForce S45 CB Radio
Red antenna warning indicator light stays on
The red light is a warning of antenna mismatch; when you hold the antenna, you are changing the match between the CB's output amplifier and the antenna. Try it with a different antenna or pick up a 'test light' (or test load) for CBs from an electronics dealer, I've also seen them with CB accessories at truck stops. If the test light fires off and the red light on the CB is dark, the antenna you have is junk.
Aug 01, 2010 | Cobra 29 LTD CB Radio
My antenna light stays on even after I have realeased the mike
Try checking the SWR's on channel 1, 20, and 40. The SWR's will change from the low channels to the mid channels to the high channels. The key is to make sure that the SWR's are around 1 or less at all three points. If the light goes out when checking one of them, then the problem is most likely the SWR's. If the light stays on when checking these channels, the issue might still be the SWR's but I would look at the grounding on the antennas. When holding the talk button on the mic and switching from calibrate to swr, can give a false reading. This is due to the calibrate circuit remaining open until you release the talk button. Take the SWR reading by releasing the Talk button on the mic after calibrating then pressing the talk button again after switching back to SWR. This will be the most accurate reading. From everything you described, I would be looking for a grounding problem with the antennas or coax, possibly even a rub though on the coax somewhere in the dash.
Dec 20, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
After keying antena lite stays on have to turn radio off to clear
Make sure your antenna is tuned properly. The light comes on when the SWR is too high. This damages the final transmission transistor. You can blow the transmit in the radio.
If you need to tune your antenna and do not know now, go here and follow the instructions...
tune SWR
there could already be some damage to the final transistor already, it may be why the light stays on. Tune the antenna according to the article and then if the light stays on again, there may be something wrong with the radio, or the warning light is not adjusted correctly.
If your swr is okay, then turn vr6 all the way down so the light does not come on.
Oct 02, 2009 | Cobra 29 LTD CB Radio
Detecting wireless network but will not connect.
1.check our IP
2.check the field strength meter of wifi that our receive, 2 or 3 bar sometimes only detect butcannot connect
basicaly nedd tansmit and receive for connect
MAYBE, just maybe, our wifi transmiter doest work (perhaps because its not set to full strength-maybe) or just broken.
Sep 29, 2009 | Toshiba Satellite A105 Notebook
Cobra 29 LTD CB Radio Logo
23 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
