Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Brush does not turn on my vaccum
The vaccum is a sears Kenmore canister type, and it has a motor that turns the brush and a light for nigth vision. neither the motor or the light work. My problem is similar except that light works intermittenly and I hear the motor running both from the canister and from the powerhead. I was told by a local vacuum repair shop that I needed to replace the hose for the reasons you specified - that the connection wasn't being made between the handle and the powerhead (something that appears to be quite common in Kenmore canister vacuums) but my problem appeared to be at the handle end with the plastic "holes" breaking apart so they didn't hold the prongs. So I ordered a new hose online and when it arrived, I found that the vacuum would run on the setting for carpet (meaning the light would turn on and I would hear the motor) but nothing happened when I tried to run the vacuum on the floor setting. I called the company that supplied the replacement hose and they think it is the vacuum's motor (not on the powerhead but in the canister). What is the likelihood that this is my problem?
  • rshourbaji3 Feb 01, 2009
    • vacume motor runs but the nozzil and roller doesnot turn
  • allysue302 Apr 29, 2009
    Bought this in January. Now, the motor runs, but it refuses to clean carpet. No light, no dirt sensor, nothing. It's like the PowerMate is dead. I am SO frustrated, as this is a NEW vacuum!!! I've cleaned out everything, checked the connection, etc. If I take it to Sears, they will keep it for 6 weeks and charge a minimum of $80. Any suggestions from home? I can't spend another 6 weeks without a vacuum cleaner.
    President:
  • 1,214 Answers
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Posted on Jan 22, 2009
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
We have a kenmore canister vacuum and it runs but when turn on the rug clener brush the brush will not run we then put on small brush head and that will work
If the power head motor runs, but the brush doesn't turn, then the belt is broken. Replace the belt and it should work.
Nov 29, 2010 | Kenmore Vacuums
I have a Sears Kenmore canister sweeper with the power mate, but it no longer has sufficient suction to pick up dirt. I took the machine apart and cleaned it, but it is still not sucking, does this model...
When cleaning the machine, did you do a good job of cleaning the beater brush and making sure it turned freely in the holders on each end? Perhaps a bit of WD40? Also, a new set of belts might help a bit.
Sep 18, 2010 | Kenmore 22812 Bagged Canister Vacuum
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Carpet setting not working, no brush turn, no light, etc.
if the motor is running, its the belt, if not there is a break in your wire likely in the stub going from the wand to the head
Oct 18, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Brush won't turn
Remove the drive belt and check the rod coming out the motor for operation when the unit is in the on position. If the motor is turning the motor is not at fault but good. Turn off unit! Next, try to turn the brush by hand. If it is hard to turn check both sides
(the ends) for hair build up. It could possibly be loaded with hair or some other type of string like material that has accumulated over the years and is restricting the movement of the brush. Also check the bearings on the ends too.
Good Luck
May 26, 2008 | Kenmore 23513 Progressive Bagged Canister...
Kenmore progressive canister
belt could be melted to the motor that spins the brush, try free spinning the brush with your hand to see if the brush spins freely, if it does not the brush bearings could be frozen, or just need a simple new belt...hope this helps
Jan 20, 2008 | Vacuums
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
720 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
