Question about KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator
The water filter button on my Kitchenaid model kscs23inss01 is stuck - any suggestions on how to fix this so I can change my water filter? Thanks!
  • 3 Answers
SOURCE: water is dispening to slow
check for proper flow and pressure on water supply line
Posted on Feb 23, 2009
sawdust46694
  • 398 Answers
SOURCE: How to change water filter of Kitchenaid refrigerator ksss36fkx00
pull the bottom cover off the lower front, you will see the filter on the left lower side. can get them at walmart ...easy to change
Posted on Jul 07, 2009
SOURCE: Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Posted on Oct 14, 2009
watcher26
  • 141 Answers
SOURCE: how to change water filter on this kitchenaid superba
go here download the manual http://kitchen.manualsonline.com/search.html?q=+kitchenaid+side+by+side+refrigerator+1&
Posted on Feb 19, 2010
  • 2468 Answers
SOURCE: I cannot remove the water
not sure on this model,but try pushing upward on the filter as you try to unscrew it counter-clockwise,some models have this feature to protect against accidental removal by bumping
Posted on Feb 16, 2011
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Frigidaire refrigerator filter status light is red
That information is in the user manual that covers your model number. Below is the procedure for a Side by Side. To look for your manual click=> HERE
Press and hold the Water Filter button
on the Ice & Water Dispenser control
panel for three seconds. When the display
changes from "Red" to "Green," the status
has been reset.
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 17, 2014 | KitchenAid KSBP25FKSS Side by Side...
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
Where is the eject button for a kitchenaid superba water filter?
I went through this same thing! You probably can't find an eject button because there isn't one on the model that you have. It probably isn't turning because it's just stuck and you have to just have confidence that you're not breaking it and force it to the left - all of a sudden, it will "pop" and turn easily.
Here is a great link to show you the different types of Kitchen Aid refrigerator filters - which kind has an eject button and which doesn't:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/149
I also found a great (and short!) video from Kitchen Aid that really helped me see how to do it. Try this one - I thought it was the best:
http://www.kitchenaid.com/content.jsp?sectionId=852
Finally knowing there wasn't an "eject" button saved me many hours of looking, and the tip about using the handles of the plyers worked great.
It is really discouraging to think you can't just screw out a water filter, but it isn't you. The directions are misleading - they don't match what you're seeing, and it doesn't twist out easily - it has to be forced....and THEN it twists out easily.
Hope this helps. It worked for me when I'd completely given up.
Best of luck!
Eileen
Sep 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water is dispening to slow
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
