Question about Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052
What color wire goes where on 3 way fan switch for westinghouse ceiling fan ?
Have 4 wires black orange yellow and purple that connect to L, 1,2, and 3 on speed switch. which one goes where
3 Suggested Answers
SOURCE: i have a westinghouse three speed fan. there are 4
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
Posted on Aug 04, 2009
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
I need to connect Orange, Yellow, Purple and Black wires from fan into the correct corresponding numbers on fan switch 1,2,3, L (0033906)
Try this; Orange - 1
Yellow - 2
Purple - 3
Black - L
If this doesn't work, you probably have the wrong switch. Just because a switch looks the same on the outside doesn't mean it's the same on the inside.
May 13, 2015 | Dryers
Which wires go to 3 speed fan switch L 1 2 3 i have a black ,orange,yellow ,purple wires?
Try this; ! - orange, 2 - yellow, 3 - purple & L - black
Aug 17, 2014 | Dryers
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
How to wire a Westinghouse 77052, which has black, red and blue wires. CIrcuit in ceiling fan has two yellow, pink off 4 uF (350K 1/2 w), Gray off 5 uF (330K) 1/2 w. Connected as follows: Pink to red;...
Copy following link for wiring 3-speed fan switches
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 30, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I forgot to write down the color connections. my options are L 1 2 3 my wire colors are, blacr, purple, yellow, blue. which goes where?
One line on the fan goes to the house common and should be white. this one is separate from the new switch. The other 3 lines on the fan are the 3 speeds. "L" is for the hot line coming into the fan and should be BLACK or RED. It should also be in the same box connector as the white above.
1,2 and 3 are the 3 fan speeds and tie to the 3 leads on the fan.
Try 1=purple 2= blue 3=yellow
You may need to move them after testing but darkest to lightest is usually the 1,2,3 order. Please let me know how much this has helped. Thank you!
Roger
Apr 02, 2011 | Westinghouse Electric Westinghouse...
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I don't know witch wires go where?
Hello. The most common configuration is: L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don
Apr 15, 2010 | Speed Ceiling Fan 3-speed Switch By...
I am having trouble installing the wiring with my westinghouse. I don't know how to match up the wires. The Westinghouse has black, white, blue, and green wires, and my house wiring is purple, yellow and...
At the fan green is ground, blue is to turn on the fan, black turns on the light. I believe at your house wiring white is neutral and goes to the white in the fan. The purple and yellow are to switch on the fixtures, you can connect the purple to the blue, and the yellow to the black.
Oct 27, 2009 | Westinghouse Contempra Trio 42" Ceiling...
I have the aloha model 5745, need to replace speed switch, which wires go where? yellow purple, black, orange;L 1 2 3
I'm an electrician and
I just replaced the speed switch on a 5745. This people at Aloha Housewares, Inc. were very nice and speedy in sending a new unit at no cost.
Connections are:
1=yellow
2=purple
3=black
L=orange
Jul 11, 2009 | Aloha Housewares (93645) Ceiling Fan
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052 Logo
74 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Terry Weaver
Terry Weaver
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
