Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
My computer operates very slowly and erraticly , sometimes at normal speed and sometimes very slowly, and even not responding at all for a few minutes. I have a Dell 9100 Inspiron with Microsoft XP Home edition. I was advised to "defragment" but I don't know how to do this. Can you help?
  • 36 Answers
To defrag your hard drive go to , start menu --> all programs --> accessories --> system tools --> disk defragment --> then select your hard drive and click defragment. This can take a few hours depending on how big your hard drive is and how much stuff you got. This may not even speed up your system. if your computer is running slow go to task manager and go to the proccesses tab and check if there is any unnessesary proccess running, if so just end them. write down the name of it and then delete it from your computer if you dont need it. :) hope that works. :)
Posted on Jan 22, 2009
2003 Kia Sedona what is the RPM supposed to idle aton cold start an in warm weather
Idle speed depends on a number of factors; for instance it may idle faster when the air conditioner is on. Instead of a fixed idle speed, as in the old cars, the engine computer sets the speed to whatever is needed to run any accessories and maintain smooth operation, but generally not more than that. That's under normal circumstances. There are several failure modes that cause erratic idle speed; usually the engine will also run roughly.
Jul 09, 2017 | Kia Cars & Trucks
Im trying to fix a p38 1999 wabcoD abs traction failure prpblem, live data for the abs sensors signal all round are the same and goes up and down with road speed.the wheel speed os&ns rear,up
Erratic signals come from the speed sensors(all that I found). At the sensors by the tires/CV axles. When I tear them apart (the bearings) they have fine metal around them. The causes the erratic signals. As you said, they seem normal at most points. But you have to watch and see where(the signal) they jump. Could be 2 MPH or 20 MPH. Replace that wheel bearing.
Oct 29, 2014 | Cars & Trucks
Acceleration problems ,at hiway speeds, needing more speed car downshifts sputters misses then eventually snaps backto normal whats up?
Ok. I'll give you my best guess, although I am not a Dodge Stratus expert. Based upon your description of the problem, I am to assume that the vehicle has problems accelerating up to speed, but once there, cruises ok unless you are going uphill or need to accelerate quickly, then power falls off rapidly and acceleration returns very slowly. If that is accurate, I would suspect the EGR valve. This is because at ihighway cruising speeds the EGR valve is pretty much wide open, letting exhaust gases back into the intake. When you need to accelerate, pressing the accelerator results in intake vacuum drop. This is partially compensated for by closing the EGR valve. If the EGR fails to close or sticks partway open, the exhaust gases will lower intake vacuum even further, and rob engine power. This can also cause the onboard computer to force a downshift to the transmission, as vacuum sensors are used to determine engine loading and the need to reduce gearing. In addition, a partially open EGR valve can cause erratic idle as it affects static intake vacuum (EGR is normally closed at idle) and the onboard computer must continually compensate, resulting is unstable idling.
Dec 04, 2011 | Dodge Stratus Cars & Trucks
I experience some problem with my 2002 odyssey. the check engine is on and when it goes up from shift to shift, it does not go the upper speed easily. As if you put the speed at position 2 and you...
Hi:
The first thing to do is to have someone check to see what code is tripping the check engine light. Most auto parts stores will do this for free. Check to make sure your transmission fluid is full, and clean. Sometimes a vehicle speed sensor can cause erratic transmission up shifting, but see what codes are tripped first
Nov 04, 2009 | 2000 Honda Odyssey
Its really slow. doesnt react easily sometimes
From the TI Knowledge Base and FAQ Hope it helps.
If a piece foreign material such as a pencil lead is lodged in the I/O port of the calculator, it may create a short causing the calculator to respond slowly to key press entries.
If the piece of conductive material can be removed, it may restore the calculator to normal operating condition.
If the material cannot be removed, contact TI-Cares Customer Support to proceed with an out of warranty product replacement.
If conductive material is not lodged in the I/O port and the calculator responds slowly to key press entries, contact TI-Cares Customer Support for further troubleshooting and resolution.
Nov 01, 2009 | Texas Instruments TI-84 Plus Calculator
Pixma MP 780 suddenly printing VERY slowly
Are you using Windows?
If so clean out your temporary files and defrag the drive.
Printers in Windows spool the job to a temporary file and then retrieves it.If the temp folder is full or the drive is fragmented this will cause your issue.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Songs Won't Sync To MP3 Anymore.
have u tried opening the mp3's folder files and dragging the music in there?
Apr 12, 2009 | Philips GOGEAR SA6045 MP3 Player
2004 Dodge Intrepid picks up speed very slowly...sometimes
you need your throttle positioning sensor replaced and set.
Oct 14, 2008 | 2004 Dodge Intrepid
Erratic idle speed
Have the fuel pressure checked. Could be an erratic pump or pressure regulator.
Poppascott
Jun 27, 2008 | 1997 Buick LeSabre
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
136 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
