Question about Samsung SyncMaster 150MP Monitor
Clicking sound I have a reoccurring clicking sound coming from the speakers. The sound happens even when the monitor is set to mute in TV mode. It happens in Video 1, Video 2 and TV modes. It goes away if I pick the PC option. Although I have not sent PC sounds to verify if it does indeed still occur. The clicking sound is random and not in any particular pattern. Any help would be great. Or if its even worth trying to get it fixed.
  • Marinetrader Jan 22, 2008
    I have the same problem but do not have anything next to my monitor.
    The monitor has been working fine for the past 3 years and all of a sudden it starts popping sounds from the monitors speakers. I muted it and it still continues. Any suggestions will be greatly appreciated.
  • Ben
    Ben Oct 16, 2008
    I recently have the same problem.
    I'm an EE though - so I cracked open my monitor and replaced the audio amplifier IC ( TDA7268 ) to no avail. When the unit is powered off, no clicking and the power to the TDA7268 is shut off upstream.
    When powered on, the TDA7268 is powered up to 12V. After a couple moments, there's an oscillation that can be heard (whine) and then the chip heats up (too hot to touch) and the clicking occurs.
    The oscillation is > 200KHz so it eventually can't be heard, but it's there and trying to drive the speakers @ 8Vp-p.
    The Speakers are the only load to the power outputs and do not cure the overheating/clicking if removed from the circuit.
    Problem Solver:
  • 18 Answers
I found the problem.
I've written up a small article on my website detailing the fix but in summary here:
Electrolytic Capacitors C826 and C835 go bad because of the heat stress applied by the audio amplifier right below them. Replacing those capacitors fixed my 150MP.
For more information see:
http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
Posted on Oct 17, 2008
  • Ben
    Ben Mar 03, 2009
    I have now fixed another one of these monitors with the same problem. So it's confirmed the clicking sound has been cause by the dead capacitors in 100% of the 2 cases I've seen.
    See my website for more information.
    -Ben
  • 84 Answers
If you keep a cell phone by the speaker that could be the issue. Some cell phones, particularly Nextel phones, cause some interference. There may also be another device close by that is causing the interference as well.
Posted on Jul 06, 2007
SOURCE:
How do I disconnect internal speakers
Some TVs allow internal speakers to be shut off when external sound is selected.
Oct 08, 2016 | Televison & Video
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
I have no sound when I go to the internet to play a video.
If your sound works everywhere else, then look for the volume setting right on the video itself. Most videos online have there own volume setting and it may be muted.
Mar 01, 2011 | Computers & Internet
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
HP dv71020us. Owned the laptop for 13 months and this never happened before. Audio does not come out of speakers until a headphone jack is placed in one of the front holes. When there is something...
Your issue from what I read is a setting issue.
you have your setting in headphone mode from what I gather and you need to place the setting for the sound card in output mode which is in the Windows sound setting.
1.Check the task bar where the speaker icon is ( Windows 7) or Windows XP.
2. Left click here and your volume control will show with a caption of "mixer" at the bottom.
3. Left click this hyper link and it will show you the properties of the speak device.
4. If you see a speak icon on the left >> click it and you will then see a tabs window
with tab label across with "general being 1st.
5. click the "level" tab and you will see the l"line in" microphone etc. They may be muted click the muted sign to enable.
6. then check sound.
Mar 19, 2010 | HP Pavilion DV7-1020US Laptop
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
The speakers are partially muted thru the TV mode.
you mean with all tv channels too? there might be an attenuation setting somewhere that has to be de-activated. Check the manuals. hope this helps and pls come back for a feedback
Aug 19, 2009 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Rhythmic clicking sound when the monitor is on
I just recently posted about this and you might have the same issue with the TDA7268 Audio Amp chip used in the 150MP that I am and currently trying to resolve.
-Ben
Mar 25, 2008 | Samsung SyncMaster 150MP Monitor
No sound from monitor
check settings on the actual monitor or right bottom corner of your screen double click on a little speaker and check its not on mute or set down.
Jan 20, 2008 | Computers & Internet
Samsung SyncMaster 150MP Monitor Logo
170 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
