Question about Video Game Consoles & Games
Older XBox 360 with wireless antenna - can't connect to network - why not?
I have an older XBox 360 white console 60 GBHDD. Purchased an EBox wireless antenna. Upgraded wireless router to DLink N600 Dual band router and a DLink wireless range extender. Still can't connect to XBox Live for gaming. Any suggestions? Clyde clydejthornhill@yahoo.ca
  • 54 Answers
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Posted on Jan 12, 2013
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
SOURCE: wireless xbox connection
Make sure you have the X-Box Adapter on the same channel as the wireless access point...If your WAP is not broadcasting the SSID then you will have to manually put it in...
Posted on Dec 31, 2007
whootsley
  • 121 Answers
SOURCE: game console and router
try xbox.com/setup or call customer support at 1-800-4myxbox if that doesnt work you can call your internet provider and they may have info on your problem
Posted on Jan 14, 2008
SOURCE: xbox live not working
XBOX SHOW E68
Posted on Jun 27, 2008
SOURCE: cant connect to xbox live through router
my xbox360 does not want to connect to wireless connection,it's been two days now..
Posted on Nov 07, 2008
How do I connect my xbox 360 to the wireless internet?
For the Xbox 360 Slim, on the dashboard console:
1) Go to Settings
2) Select "System" to take you to the system settings menu
3) Highlight Network Settings and select it
4) Select Wireless Network to setup your wireless
For older Xbox 360 consoles:
1) Your will need an Xbox 360 Wireless Networking Adapter. Check online or your local stores to see if there is one available.
2) Once you have the adapter, simply hook it up to your xbox and follow the instructions at the top of this solution to setup your wireless through the xbox dashboard.
Feb 23, 2012 | EA - Electronic Arts Video Game Consoles &...
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Cant hook xbox 2 wireless router
I'm going to assume that you are talking about the New Xbox 360 Slim that has wireless capabilities. You must go into your settings and go to the network settings. When you choose to connect wireless-ly, choose your routers signal, and if it has a passcode you must enter this in to connect to your router. If you are using the older "fatboy" xbox, you cannot connect to a wireless router unless you purchase the xbox wireless network adapter. Please note that you cannot use the wireless network on the new xbox slim if you have a network cable plugged into your console!
Sep 01, 2011 | Microsoft Xbox 360 Console
Am trying to get xbobx live for my nephews birthday, hes got the xbox 360 ellite, but its not the shinny latest model do i need a wireless adapter as well as the router that came with my broadband, but we...
If you do not have a router that you can plug directly into the back of the Xbox 360 then yes you will need to purchase a wireless router to sync up with your wireless router that you already have downstairs. You didn't specify if your broadband router had wireless capabilities? Does it? If not then you will need to buy a wireless router to be able to hook up your Xbox 360.
Microsoft has their own personal wireless router that fits on the back of the Xbox 360 nicely. I would recommend you purchase it due to ease of installation and compatability.
Here is a link to an example of what it looks like: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-n-networking-adapter/76045?ref=recpdp&cross=802124
And a cheaper older model: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-network-adapter/40678
And here is a link to Xbox step by step wirless hookup: http://support.xbox.com/en-us/pages/xbox-live/get-started/connecting/wireless.aspx
If you are having specific issues then ask away and I can see what I can do to help you out. Try to be specific on what your current setup is and what problems you are having. thanks.
Jul 16, 2011 | Microsoft Video Game Consoles & Games
How do you get connected to xbox live
What you need
  • A high-speed Internet connection such as cable or DSL
  • A router, gateway, or wireless access point (WAP) that is compatible for xbox live
  • An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only)
Configure and test
Next you need to configure your wireless settings and test your Xbox LIVE connection. The steps vary slightly, depending on your console's software.
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select the name of your wireless network.
  4. Enter your wireless network password.
  5. Select Yes if you are prompted to update your console software.
Jul 04, 2011 | Video Game Consoles & Games
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Feb 24, 2011 | Microsoft Xbox 360 Controller
I have wireless internet how do i get connect to the xbox 360
Depends if you have an Xbox Elite or an older Xbox 360?
If you have an Xbox Elite then there will be an in- built wireless, For older xbox 360's you will have to go and buy an Xbox wireless adapter.
If you go to settings, network settings, and select connect to xbox live via wireless then you will be prompted to input your security details for your Wireless and you should then be connected via wireless to xbox live.
Feb 06, 2011 | Video Game Consoles & Games
I am having problems with my dsl router
id say yes it can be done by folowing these steps on both xboxes
1. Make sure your wireless router is correctly connected to your Internet access and is broadcasting the wireless signal.
  • Step 2 Connect the Xbox 360 console to a Microsoft-manufactured WiFi adapter with a USB connection. This is different from an older Xbox console, which required an ethernet connection.
  • Step 3 Turn on the console and navigate to the Wireless Settings menu. Go to "System - Network Settings" and then finally to "Edit Settings."
  • Step 4 Configure the console's SSID to match that of the router. The SSID will be pre-selected and appear on the Xbox's display if the router is set to broadcast the SSID. Go to "Specify Unlisted Network" and enter the SSID.
  • Step 5 Set the Network Mode to "Infrastructure."
  • Step 6 Set the security of the Xbox 360 to match the router's security. Set the console to WEP or WPA encryption, whichever one the router uses, and enter the router's encryption key.
  • Step 7 Save all your settings after configuring them. Confirm that the console is connected to the network by going to the "Test Xbox Live Connection" option. This will tell you if your wireless connection is working.
  • Feb 20, 2009 | Linksys EtherFast Cable/DSL Router
    Link Your Console to Another Console
    Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
    Nov 20, 2005 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    42 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
