Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Floormate water does not come out - Hoover Floormate H3000 Upright Wet/Dry Vacuum
  • Hoover Master
  • 18,394 Answers
Check nozzle's are not blocked here is manual,
http://hoover.com/file/682/
Posted on Jan 15, 2013
  • Sandra Jan 15, 2013
    Thanks, the manual was a great help. I did find out that if you take the cleaner tank out, there is a black ring with a little indentation. If you put a small drop on hot glue right in the middle it helps to raise the mechanism enough so when you depress the trigger, it can push down the despenser enough to let out the water or cleaner. I appreciate the link to the manual as I did not have mine. Thanks.
  • Les Dickinson
    Les Dickinson Jan 15, 2013
    Glad to help
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Hoover floormate will not dispense solution
this is the original Hoover Floormate, and may have a few different things that may be wrong. First check the fresh water tank is seated or installed properly. Second, it may be the pin on the actual unit itself that is not pushing in the plunger (located on the water tank) all the way to release the solution. Check for clogs above the brush block assembly the small holes may be plugged with dried sop solution.
Sep 29, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate not suctioning water back up
I love my floormate so muck that when my first one stopped vacuuming, I bought a new one - just figured it died. Then my new one worked well until one day, it suddenly stopped.
I discovered that the filter attachment holder (the clear plastic cover over the filter) has to click into place. I guess this might not be a problem for some, but I thought it just sat there over the filter. I finally pushed pretty hard (mostly in frustration at first) and it clicked into place. Now the suction works fine.
FWIW
Jul 11, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Will not let the water down on to the floor.
Nov 08, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
271 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
