Question about Amana PTH123B25AJ Heat Pump Air Conditioner
What does the error code "Eo" mean on my Ammana PTAC
Kenmore elite model 790.4500 error codes EO 21 and EO 39. Any ideas what they mean?
yes if you go to the manufactures website and download the user guide and look in the trouble shooting guide for the error codes explanation eric
Jan 15, 2018 | Kenmore Washing Machines
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a daewoo washing machine model DWD-F1011
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
Samsung eo error
The code means that the controller or main board is having an issue with the EPROM. Take the top off and you should see a tech sheet for service persons. IT will tell you the troubleshooting steps. BE SURE TO UNPLUG THE UNIT
Jul 20, 2013 | Dryers
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
Kenmoore Electric Range - Error Code EO F2
That code means your oven is a piece of ****. Put out in front lawn on big garbage day. Get inside the oven and wait until the garbage men get there. Jump out and yell, "Surprise!". After you've had your fun go back inside, get your keys, and drive to the closest appliance store to get a new one.
Oct 05, 2008 | Kitchen Ranges
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
158 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
