We have a Mitsubishi 73" tv that produces a dark picture. This tv came without a remote...where can we access the settings menu to brighten the picture?
    Genius:
  • 1,669 Answers
You will need to buy yourself a Universal remote control that comes with a complete set of instructions to get tour TV to be controlled by it. After getting the on/off code working, go to the Menu and set up the settings.
Posted on Jan 12, 2013
lukster
  • 217 Answers
SOURCE: mitsubishi 3780D picture is way too dark
sounds like the inverter board is bad
Posted on Apr 30, 2007
  • 2315 Answers
SOURCE: NO REMOTE
I do not think there is a way to get full screen without the remote control.
Here is a link where you can find the remote.
Posted on May 01, 2008
localwonder
  • 6784 Answers
SOURCE: NO REMOTE
Hi there. The actual button option that you will need to use for this adjustment will be the aspect button and, unfortunately, this button is only on the remote and not on the TV itself. If there is a control panel located on one of the sides of this set, you may be able to push the menu button here and navigate your way threw the menus screen to the aspect option. I suspect you will need the remote.
please rate and God bless..
Posted on Mar 20, 2009
  • 6 Answers
SOURCE: no picture
I purchased four 2200uf @ 25v capacitor’s for $8 at that same repair shop. I upgraded to 25v because these will run cooler. The tv came with 10v Samxon caps that seem to be problematic in all the units they were used in. Do not buy Samxon if you do this yourself.... I opened the set by taking off the plastic back panel and then by removing the second metal panel. There are three boards and a hard drive. The board on the far left just above where the plug goes in is the power supply board. There are five data cables and one red power cable attached to it that can be removed simply by unplugging them. The board is fastened to the unit with five small screws, one on each corner and one in the middle of the right side. If you look for three green capacitors grouped together around the middle of the board and slightly off to the right, you will probably see one that is bulging out at the top. This is most likely "C235", the main problem. The other three caps that need replacing are C202, C201 and C219. C219 is closer to the top part of the board.....
The process to replace is simple, believe it or not, and it could save you hundreds of dollars. 1, Go to RadioShack and buy a cheap soldering iron and a small roll of solder. 2, Buy four, 2200uf @ 25v capacitors, online or at an electronics store. 3, Plug the soldering iron in and let it heat up. 4, Locate C235 on the back side of the board and mark the negative terminal with a felt tip marker (you want to make sure that you put the negative terminal on the capacitor through the right hole, otherwise you will pop the cap. The negative terminal is clearly marker on all the capacitors). 5, With needle nose pliers, grip the cap and pull down while heating up the terminals. The cap will eventually come out. 6, Put the new cap in (you may need to heat the solder that is left on the board to clear the hole so it can push through). 6, When both terminals are through, bend them slightly so it stays in place. Take the solder and stretch out a few inches off the roll and while holding it in one hand, lightly touch the base of the terminal where it comes through the board, with the soldering iron and the solder at the same time. --- Try not to use too much solder.. you only need a tiny drop. This will solder the cap in place. 7, cut off the terminals close to the board with some snips and repeat this on the other three. 8, put the board back in, plug in the cables. Test the TV before putting the back panels on. It should work fine if all went well..... If you hear a pop than you reversed the terminals on a capacitor and that one will need to be redone correctly.... This might sound lengthy and potentially difficult but its worth a try. Otherwise you can pay someone to replace the entire board for BIG BUCKS with the same junk caps on it and have the same problem in a year or so. LG doesn’t want to take responsibility for this and I'm sure that it has cost a lot of people a lot of money for about $8 in parts........... This worked for me and it can work for anybody with the same problem.. Good Luck!
Posted on Apr 28, 2009
ginko
  • 19396 Answers
SOURCE: Polaroid LCD TV TLA-4641C
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Panasonic TH32LRU5 picture is too dark how do you brighten?
Access the TV's on-screen menu, tab through until you find the option to increase the brightness/contrast, and adjust it.
Nov 12, 2014 | Televison & Video
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Dark picture,can't get it to brighten up with menu color settings.
Assuming brightness and contrast (picture on some sets) does not help it could be a number of things, how old is this set?
Dec 15, 2012 | Sanyo DS25390 TV
I have an old Orion TV134R . The picture is so dark on it that I need night-vision goggles to watch it . How can I brighten it up? I don't have the original remote control. Thank you.
how about in the menu button you can not get an adjustment in brightness control. if the display in the screen is too dark either in any channel or even watching a movie from an input source like dvd player, then i may say that the picture tube need now replacement.
Aug 12, 2012 | Televison & Video
CAN YOU BRIGHTEN MY PICTURE WITHOUT A REMOTE
If your TV have a menu button on its front panel, you can do it.
May 31, 2012 | Televison & Video
Can I brighten the picuture my goodmann tv without a remote control
As there is no Menu button on the frnt panel of your TV, you can't do any picture adjustments, without its remote control.
Have a 73" mitsubishi model No.WD 73734 and I have
On the TV not the remote, simultaniously press the menu and input button for at least 5 seconds. This should give an error code. If it blinks 3 times then a pause then blinks 2 times, the code would be 32. Get your error code and look in the service book at: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf -
Sep 22, 2011 | Mitsubishi WD-73734 73" Television
I have a dpx 4250 plasma tv with no remote and
Yea on set will be buttons, menu, up, down, enter/set using these buttons you can do anything you could on remote
Mar 18, 2010 | Televison & Video
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
