Sharp lc-22le22e LCD tv fault. I think I just need to do a hard reset but don't know how, My problem is-when the tv is on bbc1 and I want to say watch itv I press 3 on remote, the number 3 appears on the tv as if its going to change but it doesn't! What ever I press It stays on existing Station
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 24, 2007
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
dsacco86
  • 1077 Answers
SOURCE: need help programing a directv remote to a sharp tv, model # lc46sb54u
I know what you mean. :(
I couldn't get mine to work with my Emerson TV. No codes worked.
You may have a chance with yours. Try this link here to get and program the codes:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020#
Then if does control the TV, hopefully the input button on the remote will work.
Posted on May 12, 2009
  • 57 Answers
SOURCE: Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at www.managemyhome.com right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Posted on Feb 24, 2010
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
Very blurry picture / vertical colour lines
It sounds that the LVDS cable; the cable that connects to T'Con board to LCD panel is loosely fitted. Check it first. If it is found OK, the panel itself should be suspected. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Faulty screenshots of LCD TV screens, have been illustrated. Compare them to your TVs present screen view, and be sure. Check the site with patience.
Jun 25, 2013 | Sharp LC Televison & Video
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
Jun 04, 2017 | Sharp LC-32SB24U 32 in. LCD TV
I plug in the cable/antennae wire and it freezes up. I can't change channels or anything. if I unplug it it changes fine, then of course I can't watch tv. I have a sharp lc-s3sb23u.
See if Sharp's customer service still walks customers through what is called an INIT or factory reset. 800-BE-SHARP. Make the television do what it does when it freezes up and then call. You might just need to scrap the television because if you need another main board the part alone will cost around $600.
Sep 20, 2011 | Sharp LC-32SB23U 32 in. LCD TV
Sharp LC-19DIE-BK tv was working ok until I tried to retune to catch BBC1 and BBC2 ( on 22 June 2011), I did factory reset option then selected auto installation. Result was "no carrier...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. Do it first, and then check.
The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 07, 2017 | Televison & Video
I have a sharp 32sh12u that has a problem where sometimes i would be watching something the image stand stills then fades to sync with current frame then eventually show vertical lines. The picture will...
I don't yet have a solution for this problem, As I to have the Sharp model LC 32SH12U 32 inch LCD Tv. From what I have seen and read in searching for a relatively cheaper fix than just tossing out this $600.00 Tv,I have heard T-CON Board MANY MANY times now up until today I had a guy tell me that he was pretty certain that it is the SCREEN PANEL!!! I wouldn't think that if the screen was bad it's self it would show ANY colors or tints, Lines or what have you..I just think the T-CON Board is gone bad in this Tv As it has perfect sound, And like most everyone elses for a while after my TV warmed up it would play like a champ and had a BEAUTIFUL PICTURE until now I think the T-CON Board has gone completely out on it. Sharp must have undoubtably purchased ton's of BAD T-CON Boards that fit not only this TV but also the AOC,DYNEX,INSIGNIA,And Vizio Brand's of LCD TV's...The VERY Same T-CON board which is Part Number X3562TP ,Is futted in every one of these same brands of TV's And I feel they have gone bad in Thousands of LCD TV's and it has Obviously caused thousands of people some very bad issues with their entertainment products..my wife and I are TV Folk and that is what we do...WE watch TV,,And now that our Main TV is broken and we can't really afford to just go out and Buy a new one I have to try and repair this one,And as Cheaply as I can, So I may be about to waste $40.00 on a T-CON Board, But hey I gotta KNOW..If this don't fix it, Im just gonna part the TV out on EBAY and go for another brand of TV..I thought SHARP was a really good brand of TV, But from what I have learned..our money would have been better spent on a different brand of TV!!! If this DOES repair our Tv I will be certain to come back and let everyone know!!
Apr 23, 2011 | Sharp LC-32SH12U TV
Need details of sharp tv
Get the correct model number first and download the user's manual from Sharp. I think you meant LC-46D64U.
Apr 11, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Ldc tv with built in freeview wont tune to bbc 1 bbc 2, retuned 20 times still no bbc 1 bbc 2 . before i did retune i would receive bbc wales post code OL16 2RR North west
Buy a digital antena,or roof antena recieve better siginal,get everythings.Tries reset to factory setting retune again will get BBC1,BCC2 well get it back.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing Channels
I have found that for some reason bbc brodcasts are not transmitted in hd,either on sat or cable
Feb 17, 2008 | Sharp LC-26DA5 26 in. HDTV-Ready LCD...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
