Question about Bosch Dryers
Bosch tumble dryer fault e09
Fault e09
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
SOURCE: How do I turn off
We had a similar problem with our Bosch dryer... every now and then when we were using the dryer an alarm would go off and it would stop drying. We checked through the manual and it had no information. Then one day I noticed that there was a flap on the end of the exhaust vent outside the house. As an experiment I propped the flap open so that it never fully closes.  Now we never have the problem with the dryer. I suspect what was happening was that as the dryer was reaching the end of the drying cycle it was pumping out less and less exhaust to the point where it was too weak to open the vent flap, and the build up of exhaust in the ductwork triggered the alarm. I don't know if that's what's causing the alarm with your dryer but its worth checking.
Posted on Dec 14, 2008
  • 686 Answers
SOURCE: Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Posted on Apr 10, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    How to fix a Bosch dishwasher a anti xx with a eo9 fault
    E09
    Heating circuit fault.
    As above, this is most probably going to be an issue with the heating element as the thermistors have their own fault codes below.
    Dado
    Feb 20, 2015 | Bosch Dishwashers
    How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
    Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
    Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
    Siemens tumble dryer v36 39 - fault 9 - what is this fault??
    It seems like over heating problem or clogged went issue sometimes
    Nov 15, 2010 | Bosch Washing Machines
    Bosch Classixx tumble dryer just stopped heating - has never been very efficient from day 1. is only 12 months old! any suggestions?
    Sounds like a blown thermostat, usually caused by venting problem. If you live in a condo maybe there is a lint screen in the wall that you're not checking
    Jun 21, 2009 | Dryers
    Bosch Axxis WTL5410 condensation dryer does not heat up
    Common faults -
    1 The heating elements can fail (meaning open circuit)
    2 There are cut-outs (T.O.C's) that might need resetting
    3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
    4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
    5 Faultyconnections and burned wires may also be the fault.
    Free tumble dryer repair videos
    We have a Free full video library on appliance repair video’s
    May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
    Apr 09, 2009 | Bosch Dryers
    Dryer not heating
    Common faults -
    May 02, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
    Dryers Logo
    413 people viewed this question
    Top Bosch Dryers Experts
    Lawrence Oravetz
    MightyMikeJr
    Are you a Bosch Dryer Expert? Answer questions, earn points and help others
