Question about Bella In Box Kitchen Deep Fryer 1.2 L Handle & Lid--view Window Temp Control
My deep fryer does not turn on.
It appears my bella deep fryer plug does not work. I attach it to the deep fryer and plug it in but no lights activate.
2 Suggested Answers
SOURCE: my bella deep fryer has
1.866.832.4843
info@sensioinc.com
http://www.sensioinc.com/intro_BELLA.html
Posted on Nov 23, 2011
How to clean deep fryer
Hi There Best way To Clean Bella Deep Fryers Is To Use A Cleaning Product Called (Fry Clean) Its a Non Toxic Washing Liquid You Heat Up And Pour Out, Easiest And Safest Way Avaliable
Aug 01, 2014 | Bella Kitchen Appliances - Others
Nutrispin fryer oven
i have a bella nutrispin fryer oven model cg69a i lost my manual where can i get one
Mar 05, 2014 | Bella Kitchen Appliances - Others
My Bella Cusina deep fryer does not heat.I checked the electric cord and is ok.Also I cleaned the fryer.This equipment has been used for about a year and a half on once a week basis.
I'm sorry that I don't know much about home model products, only commercial brands....however your unit will have a heating element in it and maybe that's bad?
You could always go online, find the companies 800 number, call and speak with their service/warranty dept. They should be able to walk you through that process fairly easily, I would think? Good luck, Susan REO
Oct 30, 2011 | Bella Cucina 13401 Deep Fryer
The removable tank will not come out? isn't it suppose to come out?
I called customer service this morning and they said it was a misprint in the manual and that it's actually not supposed to come out.
Jan 21, 2011 | Bella Cucina 13401 Deep Fryer
When i went to go use my deep fryer the other day
If it uses the DP16 cordset, that is probably your problem. If not, find and press the reset button.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Mar 12, 2010 | GE 168952 Deep Fryer
IGNITION WITH PROPANE DEEP FRYER
this is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Nov 27, 2008 | Kitchen Appliances - Others
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Rival deep fryer not heating
I have a Rival Fryer Model CF250. Was working great for weeks, then after doing a few rounds of wings it quit. All lights were off and no heat.
I took the entire fryer apart and began testing connections for resistance, voltage, etc. They are very basic machines. It appears to me that my failure has to do with a diode, this particular diode sits protected by plastic and held by a srping mechanism, I assume it is the temperature sensor.
I assume that the completed circuit relies on this sensor so it being bad has made power quit.
Nov 03, 2007 | Rival CF275 Deep Fryer
Bella In Box Kitchen Deep Fryer 1.2 L Handle & Lid--view Window Temp Control Logo
19 people viewed this question
Top Bella Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
richie46
ray gallant
Are you a Bella Kitchen Appliances - Other Expert? Answer questions, earn points and help others
