Question about Confidence Power Plus Motorized Electric Treadmill
Just bought a confidence power plus treadmill plugged it on the mains, turned it on and the LED monitor showed SAFE. I put the safety magnet on and nothing happened. What can I do to make it work?
I need to purchase a replacement safety key for my pink confidence fitness treadmill and cannot find where to purchase in Australia. Need help
http://www.lifespanfitness.com.au/Treadmill-Safety-Key
just measure the diameter of the socket on treadmill and order a magnetic safety treadmill key.
Can get them on ebay but you would need to check the diameter of the sold key matches by contacting seller via ebay messaging.
this one below is from singapore $1.49 cost
http://www.ebay.com.au/itm/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock-New/172841698326?epid=2210203347&hash=item283e2b0416:g:wmIAAOSwRLlZo~B-
this one below is from australia
https://www.ebay.com.au/p/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock/26003745571?iid=282454053275&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140106155344%26meid%3D255259a17a4f4034bdd90d3236d772e0%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D192235118553%26itm%3D282454053275&_trksid=p2047675.c100005.m1851
Jan 31, 2018 | eBay Computers & Internet
T700 treadmill console not working. Plugged in & worked; reached 3mph & removed safety magnet. Console went black; won't come on. Power switch lights up; lower board led light shows power on.
The treadmill will not run if you remove the safety magnet. Replace the safety magnet and reset the treadmill. Should start working again.
Thanks.
Aug 15, 2016 | Exercise & Fitness
Treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
Dec 13, 2011 | Exercise & Fitness
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Precor 9.1 won't turn on, outlet is good. (When unplugged, switch is OK & stays in on position. Once plugged in, switch flips off and won't stay on.) Site wouldn't allow me to choose correct model -...
I'm guessing the internal fuse is blown, which is part of the safety feature when you pull the magnetic key off. You need to put the little magnetic key onto the "stop" area after each use, and it will re-set. If you take the key off "start" and the machine stops, you can't start again until you put the key on "stop". Once you do that, the main switch should work again.
Aug 21, 2010 | Precor 9.21 Treadmill
Treadmill will not start - say "Safe" on the Monitor
I'm not overly familiar with the Landice treadmills, although it sounds like it's not registering the safety key. Usually either a magnetic key or a slide key. Make sure your safety key is making good contact and if it's a magnetic key, that there's actually a magnet in it (sometimes they fall out without anyone noticing). If it's a key that you slide in to activate, see if there's any play in the port when you put the key in (wiggle it around) and if that works, the contact switch is slightly out of place. If the magnet is present and it's still not registering, either the reed switch inside the console has shifted and is too far away from the key magnet or it's malfunctioning (broken reed, shorted wire etc.)
Jun 01, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Shows "safe out" but the magnet is in?
I had the same problem, however the treadmill2_bing.gif remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable connector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Apr 14, 2010 | Bowflex Treadmill Series 7
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
Confidence Power Plus Motorized Electric Treadmill Logo
1,116 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Bill Boyd
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
