Question about Aroma AFD-615
My Aroma AFD615 Food Dehydrator stopped working
It doesn't spin or turn on at all. I suspect the fuse could be burnt. Where can I get these parts: fuse, thermostat and other electronic parts. Are there any generic options for these? Thank You A Rodriguez
I need instruction book for American Home 5 tray food dehydrator
Dehydrating is a process, so any of these should be OK for you.
[PDF]Dehydrator Manual - Nesco www.nesco.com/files/pdf/fd39_manual.pdf
  1. Cached
  2. Similar
Your Nesco®/American Harvest® dehydrator will provide both satisfying and .... to operate properly, the base tray is included as one of your 5 trays. (You may expand .... houses. Sulfating isn't recommended for use if individuals are on restricted sodium diets or ...... Eat dehydrated foods dry or rehydrate for use in recipes.
[PDF]5-Tray Food Dehydrator Manual - Ronco
https://www.ronco.com/media/wysiwyg/pdfs/5-tray-food-dehydrator.pdf
  1. Cached
Food Dehydrator. 5-Tray. White .... period of time in all the fun recipes and crafts presented in this manual or ... best part about it though is, home dehydration saves a lot of ...... their sea voyages, Pilgrims found Native Americans drying food ...
[PDF]tc-food-dehydrator-manual - Koolatron
www.koolatron.com/manuals/tc%20food%20dehydrator%20manual.pdf
  1. Cached
  2. Similar
With proper care, your Total Chef Food Dehydrator is designed to provide years of use. ... 5. Unplug from wall outlet when not in use and before cleaning. Allow to cool ... North America ... you can create by drying fruits and vegetables at home. ..... 5. Trays may be fully loaded, if desired, with pieces barely touching but not.
instruction book for American Home 5 tray food dehydrator Google Search
Oct 03, 2016 | Kitchen Appliances - Others
Tip
What is Food Dehydration all About
Food dehydration is a very long standing way of preserving food. In modern times, food dehydration machines have been developed, allowing people to dehydrate their food at home.
Dehydrators work by removing the moisture from food thus allowing them to last for much longer.
Because the water is removed at a very low temperature, the nutrients and enzymens of the food are not destroyed and that's why dehydrated food is seen as part of the healthy food movement.
How do you use a food dehydrator?
1. Wash and dry the foods you want to dehydrate
2. Arrange the slices on trays. Try and avoid overlapping.
3. Set the temperature using the guide. Generally the lower the temperature the greater the preservation of vitamins and nutrients.
4. Keep an eye on the trays, turning them in the dehydrator.
5. It can take anything from a couple of hours up to a day to dehydrate food, depending on the moisture levels.
6. When the food is ready store it in airtight plastic bags or containers.
Enjoy experimenting with your food dehydrator. It's fun for kids as well and is a great way of preserving fruit and vegetables when you've overbought or can see food would otherwise go to waste.
on Jan 02, 2014 | Kitchen Appliances - Others
NESCO FD-75PR Food Dehydrator quit working. Can I repair it? Company was very unhelpful. Suspect it was heat related? About how much are parts and where do I buy a part?
Does the fan run and just won't heat or is it completely dead. If the fan runs ok then look at the temperature dial. That is the thermostat. It could be bad. Next to check is the heating element itself to see if it isn't open. There's an inline safety device that may have opened too. It looks like a small silver cylinder with one end narrowing to a point. That usually goes first. Try googling Nesco parts to see if any parts are available.
Sep 11, 2014 | Kitchen Appliances - Others
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Where is the crofton food dehydrator power switch?
my crofton food dehydrator just stopped working after the 3rd use. I bought it from Aldi and since I lost the receipt they said they will refund me if I mail the whole thing to them which means I will end up paying more than what they will refund me. Any idea of how I can get repaired. Mine had no power switch and the manual doesn't state what problems might occur.
Aug 02, 2012 | Kitchen Appliances - Others
Hi, my Saeco Aroma 1st generation won't turn on anymore. I opened it up but can't find the fuse nor thermostat to verify, there is no sign of burn or open wire. Would you help me to locate them...
Exploded diagram at the link below. Parts are in Italian but these can easily be translated on the web. ( translate.google.co.uk )
http://www.partsguru.com/user/AROMA%20SIN%20015%20Aroma%20MANUAL%20.pdf
Their should be an internal fuse located close to where the mains flex enters the unit.
If their doesn't appear to be one then the first item to check would be the main switch (Item 26 on Page 1).
You'll need either a multimeter to check that with the mains on, and the switch in the on position you're getting a supply to the secondary side of the switch (be very careful if you do this as working with live exposed equipment can be dangerous). Your other option is to use a continuity checker and with the mains off and unplugged, place the continuity checker across the switch and move the switch to the on position. If the switch is OK then the continuity checker should either buzz or flash depending on what tyre you're using.
If this fails or you require any further guidance then just ask.
Jun 27, 2011 | Saeco Aroma Espresso Machine
My Salton Food dehydrator just stopped working. Turned it on for the first time today and it remained on for about 10 minutes and now wont turn back on.
If this is a Salton dehydrator that stopped working why are you referencing Gardenmaster dehydrators which is Nesco/American Harvest?
Feb 05, 2010 | Nesco Gardenmaster Digital Food Dehydrator
Hi I purchased a Nesco food dehydrator at a yard sale and need a manual for it . Model fd60, can I print one off the internet for this model?
I would think that any dehydrator information would work for you.
You just have to be sure the components are working (ie. fan and heating coil.) A dehydrator is pretty basic.
http://www.food-dehydrator.com/food-dehydrator/books.aspx here is a link for books on a site that sells the product.
You can find a lot of books at the library too.
This might also help, dont let the name fool you: http://www.astray.com/recipes/?show=Dehydrator%20general%20instructions
With some searching on line you will be able to find a lot of instructions and probably even ones for your specific dehydrator.
Look on forms about drying foods and ask for the basic instructions if you find you really need them after looking at the links above.
There might be someone willing to scan them and email them to you.
Dec 15, 2009 | Nesco Crock Pots & Slow Cookers
Aroma AFD-615 Logo
56 people viewed this question
Top Aroma Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
