Washer shakes during spin cycle - Washing Machines
    New Friend:
Sounds like the washer is off balance,washers have leveling feet you should adjust 1 or all until when u push the washer it does not move.If you still have this problem it could be the wash tub itself,always make sure when you load your washer to evenly distribute your clothes too.Hope this helps.
Posted on Jan 12, 2013
it's possible your load is unbalanced, if this is the first time this has happened
Mar 17, 2012 | Kenmore Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Excesive Shaking during spin cycle
Your washer has self adjusting rear legs . Tilt the machine foreward and look at the back legs . If one is stuck in , use a screwdrive and pry it out till both legs are in the out position . Set washer back down slowly and the rear legs will automatically adjust .
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
