Question about Kenmore 24032\24036 Top Load Washer
Kenmore 110 16882502 topload washer will not spin dry
Clothes are not completely spinning dry. What could be the problem?
SOURCE: Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Posted on Feb 27, 2008
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
SOURCE: kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
Posted on Jul 04, 2008
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
  • 100 Answers
SOURCE: Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Posted on Aug 09, 2009
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore topload washer pumps water out but won't spin.
your basket drive has gone out on you.
cost high to repair
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer spins but doesn't spin the clothes dry anymore
If it's a Whirlpool toploader, or a Kenmore with a model number starting with 110.XXXXXXX, then you have oil on your clutch. You'll need a gearcase, clutch, and motor coupler. Test this when empty by putting the machine into spin, activate the lid switch, and place your wet hand on the inside of the spinning basket. If your wet hand can stop the basket easily, it's the clutch.
Another telltale sign: oil sprayed around the inside of the cabinet at the height of the clutch.
Mar 10, 2008 | Washing Machines
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
97 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
