Question about Abit AS8 Motherboard
Abit as8 post codes 21
When booting up it stops at post code 21
  • Abit Master
  • 3,606 Answers
Hello here is the homepage:
http://abit.ws/page/mi/download/download_driver_detail.php@pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AS8&pSOCKET_TYPE=LGA775
Post code 21, is a memory/ chipset problem.
It could be a problem with a ram module, or a Pci sound card or a graphic card. or powersupply.
Try to remove any add in cards, and try to boot with only one stick of ram.
Good luck
Posted on Feb 17, 2013
  • 32 Answers
SOURCE: Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
Posted on May 09, 2009
Testimonial: "Thanks. And I sold the replacement motherboard that I did not need to buy!"
  • 17 Answers
SOURCE: ABIT AN7 MAINBOARD HANGS @ POST CODE 90
I had the same problem, the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.A hot flash worked for me for this mb and an Epox 8rda+,i also have backup bios chips now.Your chip is a Winbond,4 mb capacity.
Hope this helps, SSVik
Posted on Jul 11, 2009
  • 27 Answers
SOURCE: Post code 99 in motherboard abit al8
check your motherboard's owner manual. Try removing the processor/ram/video card to see if that will give you any clues.
Posted on Sep 30, 2009
mace1mace
  • 1138 Answers
SOURCE: abit av8 bios post codes 8.3 - 8.6 - 9.C
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
Code C0
Try clearing your CMOS it might be a bad BIOS setting preventing it from booting, also if you have a spare memory chip laying around or can borrow one from somebody try booting it with different RAM
Dec 06, 2013 | Abit AS8-V Motherboard
Abit 1-450c manual
http://www.ps2netdrivers.net/drivers/abit.as8/
Mar 05, 2013 | Abit Computers & Internet
I get a POST code of 00 then after i hit the power on i get 83 then 96 then 9.F. help my pc wont start and i`ts no beeps.
If no beeps your MOBO is fried.Is no worth to try to fix.Instead i suggest to get a new one.
Dec 19, 2010 | Abit AS8-V Motherboard
I picked up a discarded complete computer with Abit AS8-V motherboard and standard CPU. The entire assembly had been immersed in floodwater. After cleaning, drying, and waiting a few days I powered it up....
Simple test: disconnect the hard drive and the optical unit and try to boot in BIOS. If you can't then the first thing you should check is the memory, followed by the processor. If you can then the hard drive is dead.
Mar 13, 2010 | Abit : AS8-V...
On the start the digital give me the code E6
E6 on Phoenix BIOS is the BIOS ROM chip.
Mar 01, 2010 | Abit AS8 Motherboard
Board won't pass post code 18 and not sure what or why
Postcode error 18 ( Usually means ) System timer fail.
re-seat The RAM ( Memory ) or check the memory is of the Correct Type for the Motherboard. ( DDR-DDR2 )
This is most Likely A RAM Problem.
Mike @ Compurepair.
Dec 01, 2009 | Abit AS8 Motherboard
Can i?
An attractive value of dual core processors is that they do not require a new motherboard, but can be used in existing boards that feature the correct socket. Check sockets if same then enjoy.
Jun 05, 2009 | Abit AS8 Motherboard
As8-v abit motherboard
Hi, the most common cause of this type of problem is the on/off switch on your case. See if you can get a spare one from another computer and plug it onto your board in place of the original one for a test. If this is not the cause then it would be worth checking the power supply, even if there is a LEED light on the motherboard there could still be insufficeint power to boot up. Regretablely the next conclusion is your motherboard. Goodluck with this regards mistyman
Aug 13, 2007 | ASUS A8S-X Motherboard
Abit AS8 Motherboard Logo
114 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
