Question about Coleman 5033-700 Utility Heater
How do you light colman propane catalytic heater #5033
3 Suggested Answers
  • 193 Answers
SOURCE: heating problem
inside its a sensor or limit thats shutting it off
Posted on Jan 25, 2010
  • 4736 Answers
SOURCE: my colman forced air propane
No, it's not normal.
There are two things that can cause the problem: Low gas pressure or poor air intake at the air shutter control on the burner(s). The air intake may simply be clogged with dust and lint. In which case, you can clean it with a vacuum that has a hose and crevice tool attachment. Vacuuming the burners will also help.
As far as the low gas pressure is concerned , be sure your tank has enough gas to carry the heater. It may be running out. Gas pressure will have to be professionally checked.
The cleaning part, you can handle.
Hope this helps resolve your problem.
Posted on Feb 26, 2011
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
My colman forced air propane heater is burning very yellow is there a way to adjust it to make it right? or is that normal
Feb 26, 2011 | Coleman Propane Forced Air Heater...
My coleman 5033-700 does not have a ignite button, so how do i light it?
Turn the knob to the light position, light the heater with one of those long bic lighters or a match, turn the knob back to the run position. Takes a little while for the catalytic mat to fully light up.
Jan 12, 2011 | Coleman 5033-700 Utility Heater
Colman fernace blinking code 9 what is this
there should be a trouble code index on the panel that shows the wireing diagram good luck
Oct 03, 2009 | Coleman Propane Forced Air Heater...
Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Colman Furnace keeps kicking on & off
Denise, my heater not a coleman (a monitor heater (oil) kept turning off when the temp got really cold. I would advise you to ask if you can do this, I addded an additive to my drum outside which holds the fuel. Because the deisel thickens up when it gets cold, which makes the heater have a harder time distributing the fuel to the heater. So far the heater has not kicked off.
Jan 09, 2009 | Coleman Propane Forced Air Heater...
My colman heater pilot lite is on but the main heat does not work
First of all DO NOT try to fix this yourself. Call a qualified repair tech. The pilot valve in your main gas valve is stuck open and will not allow the main valve to open. I repeat DO NOT attempt to repair this yourself. LP gas is not forgiving.
Dec 28, 2008 | Coleman Propane Forced Air Heater...
Colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Oct 03, 2007 | Coleman Propane Forced Air Heater...
Coleman 5033-700 Utility Heater Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
